New ethercat / probe basic control for minimonster
1 year 15 hours ago #337636 by rodw
immediate homing is covered here  linuxcnc.org/docs/stable/html/config/ini...ml#_immediate_homing
But spending an hour wiring home switches will be well worth it!
I could not use a machine without home switches and yes I tried!
1 year 15 hours ago - 1 year 15 hours ago #337637 by Hakan
so if i home and crash, is there something in the controlword and statusword i should see? it happens in a few ms.
Use halscope to record, it catches every ms.
If I look at cia402 code the only reason I can see (but I might miss of course)
is that it does an auto fault-reset due to it receiving a fault code.
Halscope.
And thumb on e-stop.
Last edit: 1 year 15 hours ago by Hakan.
1 year 15 hours ago #337638 by ihavenofish
Yup, that's what's not working as expected. It has zero effect on homing.
The section after that is what ill try that tomorrow. That hopefully at least will tell me if linuxcnc is causing the motion, or the drive.
1 year 15 hours ago #337640 by ihavenofish
Halscope.
OK, ill try that tomorrow.
1 year 5 hours ago #337674 by ihavenofish
ok, first things, i had the values for controlword and statusword reversed. sigh. haha.
This is aggravating. I am seeing some "blip" on the statusword periodically, but i'm not able to capture it.
i did determine that when i power off and power on the servos, they read 0. so if i physically move the machine to the right spot the machine can safely home with motion so it wont crash...
so individually we will record a bunch of pins during homing.
statusword
controlword
opmode
ill be doing this after lunch. what other pins should i scope?
11 months 4 weeks ago #337697 by Hakan
Start with controlword, statusword, opmode and opmode-display.
Time to create page: 0.384 seconds
