New ethercat / probe basic control for minimonster
1 year 8 months ago #321027 by ihavenofish
iwlwifi-2030-6.ucode
1 year 8 months ago #321028 by rodw
I did not know it was a wifi card. Why don't you just plug to a wired network until lts installed? I never use wifi for installations.
Trixie should support it as its up to 2024 version
sudo apt install firmware-iwlwifi should do the trick on Trixie.
packages.debian.org/search?suite=trixie&...mes&keywords=iwlwifi
1 year 8 months ago #321029 by ihavenofish
no wired connection.
fixed now. this is my frustration with linux. it said you are missing this file, put it on a usb and continue. NOWHERE does it say no, don't do that at all, go get this .deb file of intel stuff instead.
They first make it deliberately difficult, then make the instructions deliberately obtuse assuming everyone already knows everything there is to know about linux.
And then they wonder why it never really makes more headway with the masses.
Well that was a waste of several hours for nothing.
1 year 8 months ago #321032 by ihavenofish
finshed installing.. reboots..... no operating system installed.
*slams head on desk*
Now what? its the only disk in there.
1 year 8 months ago #321033 by tommylight
Try Linux Mint Debian Edition 6
www.linuxmint.com/download_lmde.php
Try the live version, if everything works, almost always it will work after installing it on the drive.
To install LinuxCNC use the same
sudo apt install linuxcnc-uspace
ASUS ROG Crosshair VIII Impact - AMD X570
1 year 8 months ago #321035 by ihavenofish
Already done here.
The no OS found is a lenovo thing I forgot about. needs a bios flash. doing that now.
Time to create page: 0.452 seconds
