New ethercat / probe basic control for minimonster
1 year 8 months ago #321019 by ihavenofish
Well now I'm stuck. its asking for non free intel drivers. I put them on a usb stick but linuxcnc installer cant find them. I'm sure ive done something simple wrong here, but i dont see it.
1 year 8 months ago #321021 by rodw
I'm not feeling authoritive here but Debian Bookworm split the earlier non-free  into non-free (not in the default) and non-free-firmware (included in the default). We include non-free in our apt sources but I don't know if the installer refers to that as it runs.
When I faced this earlier with the Odroid H3+, I had to install Debian without  a network driver and install it after installation and run the NIC installer. This will set your /etc/apt/sources.list to only use a CDROM so it will need editing to be something like this
deb http://deb.debian.org/debian bookworm contrib main non-free-firmware deb http://deb.debian.org/debian bookworm-updates contrib main non-free-firmware deb http://deb.debian.org/debian bookworm-backports contrib main non-free-firmware deb http://deb.debian.org/debian-security bookworm-security contrib main non-free-firmware
1 year 8 months ago #321022 by ihavenofish
From my last go linuxcnc does no install correctly without the network first installed. But last time I got the non free one separate from linuxcnc and not the official one. I was hoping the official one would make this all just work smoothly, but noooo.
What I don't get is why it asks for a usb but then does not recognise it when i put it in.
1 year 8 months ago #321024 by rodw
You could try installing Trixie CD  which is now in alpha release
www.debian.org/devel/debian-installer/
Once you sort out your network install linuxcnc from their repos
 sudo apt install linuxcnc-uspace linuxcnc-uspace-dev
This should also install PREEMPT_RT
This will get you a very late version of 2.9.3 which is basically the same as 2.9.4
Then to hook up the Ethercat repos, try this script
forum.linuxcnc.org/ethercat/53785-instal...thercat-repositories
and click through to the install instructions in that link
This could be a bit experimental as Trixie is using the 6.12 kernel which was not supported by etherlabmaster. But I raised an issue with them that should have fixed the issue 2 days ago.
gitlab.com/etherlab.org/ethercat/-/issues/160
1 year 8 months ago #321025 by ihavenofish
Yeah this seems like trading one problem for many more problems. haha.
I just need to figure out how to make it read this driver. can you not just stick it onto the installer usb like you do with windows drivers?
1 year 8 months ago #321026 by rodw
I have no idea. What is the driver? Link? is it supported in later kernels?
Time to create page: 0.347 seconds
