beta bulleri for retrofit?
- Masiwood123
- Thank you received: 93
28 Oct 2025 03:09 #337335
by Masiwood123
beta bulleri for retrofit? was created by Masiwood123
Hello everyone, I got this machine through an auction, it is in good physical condition, but with a controller that, even though I have the parameters, will not perform referencing, simply the switch that supplies power to the drivers will not stick if I hold the z axis, it goes up to the limit switch, turns off the drivers and an error axis error appears. The motors are dc servos with analog input for the drivers and have 500 pulse encoders. my question is whether the Mesa 7i96s+7i77 can satisfy that the motors remain and that the rack ATC will somehow work later. Thanks in advance for your future support.
- Thank you received: 7509
28 Oct 2025 08:14 #337346
Replied by tommylight on topic beta bulleri for retrofit?
I would try for sure to keep the motors and drives.
Does it have schematics?
The following user(s) said Thank You: Masiwood123
- Masiwood123
28 Oct 2025 08:59 #337347
by Masiwood123
Replied by Masiwood123 on topic beta bulleri for retrofit?
there is a schematic but very weak, I can find out which cables are for encoders and analog inputs for drivers, which is enough to maybe tune the motors, but there are a lot of inputs and outputs of some inductive sensors and the like, so the schematic is a bit useless, I would have to see what activates what. I'm worried because maybe the switch for the drivers is faulty, (see the attached video) plus x, y don't move and I had to remove the driver for z because when I turn on the drivers and hold the z axis it goes up or down quickly.
youtube.com/shorts/p0F6iMwsQ_s?si=DSToSnipQkql-Ad2
28 Oct 2025 10:54 - 28 Oct 2025 10:55 #337349
There is a failed power supply somewhere, for sure, so start by checking voltages, usually they are marked on the boards.
And please, please do not do that "on-off-on-off" thing quickly, that is how machines are broken, give it 5 to 10 seconds between tests.
Edit,
upload schematic here so we can have a look.
Edit,
Last edit: 28 Oct 2025 10:55 by tommylight.
- Masiwood123
28 Oct 2025 11:52 #337352
by Masiwood123
I managed to change the parameter for the z axis to change the poles of the motor, I slightly reduced the trimmer for ``speed'' on the driver and now it wants to turn on the power for the drivers, all the lamps are green and the motors are energized and do not turn...however, according to the instructions, it asks for the first referencing, so anything else unfortunately throws an error and the referencing will not start, I will also have a screenshot tomorrow in pdf or image format of schematics, I guess I will have to to do a retrofit
- Masiwood123
29 Oct 2025 07:01 #337394
by Masiwood123
- Masiwood123
29 Oct 2025 07:04 #337395
by Masiwood123
here is schematic, i have to find wires to pass controller end to enable drivers first before retrofit.
- Masiwood123
07 Nov 2025 13:43 #338046
by Masiwood123
Sorry for the poor English, thanks for your help in the future.
- Masiwood123
09 Nov 2025 05:34 #338111
by Masiwood123
- Masiwood123
09 Nov 2025 09:19 #338118
by Masiwood123
Time to create page: 0.343 seconds
