- Thank you received: 10
I don't beleive there is anything stopping you from using 2 mpgs at once. Its just most examples are based on a hand held encoder. See if you can find photos of Andy Pugh's lathe. I think it was a Holbtook. He has the two MPGs on it and he went as far as getting castings made to match the original lathe.Hi Timo,
There’s no rush on my end. I want to thoroughly research which control system to use first. The issue seems to be the two handwheels that can be used simultaneously. It worked well with Mach3 using two printer ports, but I’m looking for something more modern.
Hans
