Gcodetools - Inkscape's CAM extension
- Nick
- Thank you received: 15
18 Sep 2012 14:20 #24369
by Nick
Replied by Nick on topic Re:Gcodetools - Inkscape's CAM extension
I've got almost the same behavior:
Create new file + save (as) 1.nc = Gcode
Create new file + save (as) 1.ngc = Text
Create new file + save (as) 1.ngc + close file + open 1.ngc = Gcode
So it appears that it looks only at the first option in the .lang file to determine language when saving the file.... But when you Open file it looks through all possibilities...
- 777funk
18 Sep 2012 14:42 - 18 Sep 2012 15:07 #24371
by 777funk
Replied by 777funk on topic Re:Gcodetools - Inkscape's CAM extension
I think you just figured it out. That seems to be the case.
EDIT: I'm not sure about that now. I have a bunch of very simple .nc files and just opened one and it defaults to plain text.
So open doesn't always work either.
EDIT2: I just put ONLY *.NCD in the file types and now it works. For some reason it's not liking the mulltiple file types.
Last edit: 18 Sep 2012 15:07 by 777funk.
- 777funk
18 Sep 2012 14:56 - 18 Sep 2012 15:01 #24372
by 777funk
Here's what I'm using. It opens as plain text as the lang.
ok not letting me upload it as .nc. Weird for a CNC forum. I suppose I could change it to a .txt but all there is to it is basically a G90 and some G00 and G01 commands.
Last edit: 18 Sep 2012 15:01 by 777funk.
- Nick
18 Sep 2012 15:04 #24374
by Nick
Just pack the file with tar.gz or zip, and forum will accept it.
- 777funk
18 Sep 2012 15:12 - 18 Sep 2012 16:30 #24375
by 777funk
Just edited post #24371 after more tests.
EDIT: Too weird... I just redid a few things in your code and now .NCD works but .nc doesn't.
Here's what I did:
I just changed the file types and put "Sources" in the _section since I saw other languages had Sources instead of Other.
I don't think changing "Other" to "Sources" did anything. But not sure there. Haven't tested it.
EDIT2: Some .nc files open as Plain Text and others as GCode. If I save one as GCode language it will later open with GCode.
Here's what I did:
<language id="gcode" _name="Gcode" version="2.0" _section="Sources">
<metadata>
<property name="mimetypes"></property>
<property name="globs">*.nc;*.ngc;*.ncd;*NCD</property>
<property name="block-comment-start">(</property>
<property name="block-comment-end">)</property>
</metadata>
Last edit: 18 Sep 2012 16:30 by 777funk.
- Nick
19 Sep 2012 10:28 #24411
by Nick
Hmmm... I'm totally confused.
If we
Create new file + save as ngc = Text file
Create new file + save file as .nc + save as ngc = Gcode languge
Create new file + save file as .c it becomes C + save as ngc = Gcode languge
It appears that it wont change file parsing type only if saving from the text file...
If we
- 777funk
13 Oct 2012 02:20 #25283
by 777funk
In GEdit Is there a way to do math operations to say ALL Z-axis coordinates?
in other words shift all of the Z's up by a set amount?
- Nick
17 Oct 2012 11:40 #25401
by Nick
I'm afraid no.
But you can use Regular expression extension for that.
for example, change
Z([\-\d\.\s]+)
to
Z[#<zoffset>+[\1]]
and define #<zoffset> = 10 at the top.
Or you can use parameterize Gcode postprocessor from Gcodetools to add this parameters to Gcode automaticaly.
for example, change
Z([\-\d\.\s]+)
to
Z[#<zoffset>+[\1]]
- Thank you received: 4964
15 Feb 2013 08:58 #30082
I have been trying to use gcodetools to create lathe G-code, and I don't seem to be able to figure it out.
I have a profile in Inkscape. X is vertical, Z is horizontal.
All I seem to be able to get is a profile in XY with several Z steps (not ideal for a lathe).
Could you possibly give a step-by-step of how to create lathe G-code from a profile in Inkscape?
(And does the G-code always contain Y coordinates? That seems wrong)
Replied by andypugh on topic Gcodetools - Inkscape's CAM extension
I've remade Inkscape plug-in and want to share it
Lathe machining
- walt_scrivens
24 Apr 2013 06:26 #33103
by walt_scrivens
Replied by walt_scrivens on topic Gcodetools - Inkscape's CAM extension
I'm having a problem with area fill. I can get the area filled in properly with the Area tool, and the drawing looks correct. When I generate the gcode, it still looks good in inkscape, but in the actual .ncg file, some paths are repeated over and over - 55 times in the attached file!
I've been deiting the duplicate paths out with Gedit, but that's tedious and unnecessary. Any ideas what I might be doing wrong?
Walt
Walt
Time to create page: 0.096 seconds
