Many thanks Todd! I am not completely shore if this is of any value, the Bobcad has in the selection of tools, a set of options with a spot to set the "slowdown for the corner", it offers a 100% slow down, I just think that would do it. I will look and try to understand all that you included in your response. Help me understand what one should expect from cutterpath software, will I be able to set up a master template with the essentials, like you describe included? Should when cutting a pocket, to get the best most efficient path will I need to edit, most times? Like the example above, it had some long runs with tool not cutting. The mist is manual. Todd, many thanks for your help, I really appreciate it. Is there a way to simulate in linuxcnc w/o running the machine, so you don't have to tie the machine up?
many thanks!
