LinuxCNC do not follow the gcode path
- Pfaff
02 May 2018 20:55 #110051
by Pfaff
LinuxCNC do not follow the gcode path was created by Pfaff
Hello,
there is a problem I get in LinuxCNC - there are some radiused path (red path) without following the gcode trace (white path).
I defined a laser tool with a diameter of 0.25mm - but I changed this from 0mm to 3mm without any changes. I would be glad if anyone can give me some advices how to force LinuxCNC to follw the gcode path exactly.
Thanks!
Best regards
Tobi
Thanks!
Best regards
Tobi
- Thank you received: 1449
02 May 2018 21:07 #110053
Replied by Todd Zuercher on topic LinuxCNC do not follow the gcode path
What are your G64 settings?
The default is G64 with no P, which is maximum blending.
Set G64 P0.005, or something similar which limits the blending (corner rounding) to the tolerance specified by P.
The following user(s) said Thank You: Pfaff
- Pfaff
02 May 2018 21:16 #110055
by Pfaff
Replied by Pfaff on topic LinuxCNC do not follow the gcode path
Thanks ! This was the solution. Many thanks for the quick answer.
Best regards
Tobi
Best regards
Tobi
Time to create page: 0.109 seconds
