- Thank you received: 8
Fusion 360 G3 errors SOLVED
- tightmopedman9
7 years 9 months ago #123732
by tightmopedman9
Replied by tightmopedman9 on topic Fusion 360 G3 errors
I encountered this issue when a tool offset in the tool table was added. Changing the offset back to 0 fixed the issue.
- Hakan
- Thank you received: 454
7 years 9 months ago #123736
by Hakan
Replied by Hakan on topic Fusion 360 G3 errors
Yes, tool offset and/or nose radius should either be in linuxcnc or in Fusion. Not both.
If you haven't changed anything in Fusion it will do toolpaths after the tool setting in Fusion.
Nose radius should be zero in linuxcnc then.
It should be possible to do the other way, it is an active choise in one of the tabs.
- Roland2161
7 years 9 months ago #123738
by Roland2161
Hakan how do I access the tool table in emc2? I need to set the radius in the machine to 0.
Replied by Roland2161 on topic Fusion 360 G3 errors
Hakan wrote: Yes, tool offset and/or nose radius should either be in linuxcnc or in Fusion. Not both.
- Hakan
7 years 9 months ago - 7 years 9 months ago #123740
by Hakan
I assume you use the "axis" gui? There should be an item "Edit tool table..." in the File menu. An assumption though, I use another gui.
Last edit: 7 years 9 months ago by Hakan.
- Roland2161
7 years 9 months ago - 7 years 9 months ago #123741
by Roland2161
I think I figured out the tool table. But I am still having problems with the program. Program attached.
It says "near line 265 arc radius to small to reach end" so I deleted that radius down, and the program will run without the last bit of program. What gives? Any idea? Just a bad design then?
Hakan wrote: I assume you use the "axis" gui? There should be an item "Edit tool table..." in the File menu. An assumption though, I use another gui.
Last edit: 7 years 9 months ago by Roland2161. Reason: wrong program
- OT-CNC
- Thank you received: 75
7 years 9 months ago #123747
by OT-CNC
Replied by OT-CNC on topic Fusion 360 G3 errors
Have you tried diameter mode G7? Also try outputting the g code with I and k.
I recall having a similar issue a while back using radius format arcs. R in G2/G3.
