Fusion 360 G3 errors SOLVED
- Roland2161
7 years 9 months ago #123610
by Roland2161
Replied by Roland2161 on topic Fusion 360 G3 errors
I am a mill guy I just threw Y in there by mistake my program is correct. I am still researching how linuxcnc works to get up to speed. I have a linux mill as well that I am diving into too.
As far as the pre format code I had put that stuff in before running the program. Cutter comp could very well be the issue, i just need to figure out how it works on this machine before I go further it seems. How do I view what is currently in the machine for cutter comp? Is there a list that can be brought up? I am running emc2 it what it says on the main screen.
- Roland2161
7 years 9 months ago #123614
by Roland2161
No 360 does not have a lathe processor for linuxcnc, it does however have one for mill though. What cam software do you use Hakan?
- Hakan
- Thank you received: 454
7 years 9 months ago #123618
by Hakan
Replied by Hakan on topic Fusion 360 G3 errors
I use Fusion 360 for milling and turning. Don't remember where I got the lathe post processor from.
I'll attach it here. It has worked fine for me for a long time. Disclaimer, etc.
7 years 9 months ago #123643
Replied by andypugh on topic Fusion 360 G3 errors
G3 radius and and point will be wrong if the machine is not in the correct radius / diameter mode. G7 / G8
You also need to be in the correct plane (XZ plane) G18
And, finally, the relative / absolute arc centre needs to be correct. G90.1 / G91.1
- Roland2161
7 years 9 months ago #123730
by Roland2161
All this is accomplished. Problem has been narrowed to the cutter comp, tool tables. G7 G8 could also be an issue but will focus on that next. Once I get these programming errors solved this machine should be 100% functional.
- Roland2161
7 years 9 months ago #123731
by Roland2161
How do I pull up the tool tables to see what is in them?
I changed tool nose radius in 360 to .008 and set radius error to .000000001 and now I passed the radius error and I got a gouging error which, after what I just read in the manual could be caused by improper tool offsets, radius etc.
Time to create page: 0.879 seconds
