dxf2gcode - plasma enhancements
4 years 11 months ago #225175 by tommylight
Replied by tommylight on topic dxf2gcode - plasma enhancements
That is good to know. Clearly a capable and talented chap.
Well, i am not allowed to give you his info so you can do a quick search on the net, he comes up often on the results! :)
4 years 11 months ago #225191 by Grotius
Replied by Grotius on topic dxf2gcode - plasma enhancements
Just to let you know. Cam has a deb installer for a few days now.
It's usefull for plasma, milling and laser machines.
The program can be modified with qt. For example add a save_file_as button somewhere.
github.com/grotius-cnc/cam/releases
The following user(s) said Thank You: tommylight, Joco
4 years 11 months ago - 4 years 11 months ago #225888 by Joco
Replied by Joco on topic dxf2gcode - plasma enhancements
As an FYI installed this per release instructions on Debian 11.  No menu item showing, even after reboots.  Also the command (assuming it is cam) is not being found in the command line search path.   Looks like it is installed to /opt.
Suggested additions to release notes:
1. make the sudo install commands that have a long list not have hard returns in the line.  I did a copy and paste and didn't discover there was problem until later as I had missed the errors that the second two lines were missing the apt install command as the copy/paste had treated the text as 3 distinct lines with line-returns at each end.
2. note where the install is being placed. That way if menu's don't appear you know where to look.  I just happened to get lucky that /opt was the first spot I stated hunting.
Still a great tool with a lots of potential to give a "simpler" yet powerful alternative to the likes of SheetCam.
As a side note, still not able to run under Debian 11.   Getting errors such as:
./cam: error while loading shared libraries: libTKPrim.so.7: cannot open shared object file: No such file or directory
Probably some search path issues but I have no idea where to start fixing it.
Cheers - J.
Last edit: 4 years 11 months ago by Joco.
4 years 11 months ago - 4 years 11 months ago #225926 by Grotius
Hi Joco.
Ai. LibTkPrim is a opencascade lib. If you install this deb package it should work, normally :
github.com/grotius-cnc/oce/releases/tag/1.0.1
If not, you can follow the readme install instructions for build from source : github.com/grotius-cnc/oce
It is certainly powerfull. I remember, i coded it in a few day's for you.
Currently busy coding something else, a boston dynamic dog.
But i will take a look in the near future to give it some
extra functionallity.
Thanks for your feedback.
Last edit: 4 years 11 months ago by Grotius.
4 years 11 months ago #225933 by Joco
I went back over the install instructions diligently.  Different error now.
./cam: symbol lookup error: ./cam: undefined symbol: _ZdlPvm, version Qt_5
So the libs are being found but something not right.  What version of QT5 am I supposed to be using?
Key system data:
    Qt Info         Qt Version:     5.15.2         Qt API:         PyQt5         Qt API Version: 5.15.2     System Info         Description:    Debian GNU/Linux 11 (bullseye)         Kernel:         5.10.0-9-amd64         Version:        #1 SMP Debian 5.10.70-1 (2021-09-30)         Ram:            4 GB
Cheers - J.
4 years 11 months ago - 4 years 11 months ago #225938 by Grotius
This will install an extra qt in the /opt/ dir.
github.com/grotius-cnc/Linux-Pro/release...1.0.0/qt-creator.deb
Try if it's solved.
It could be that i compiled cam with CONFIG += c++20 is the actual problem for you.
That should then be c++ 11 to avoid any errors.
Time to create page: 0.546 seconds
