ViaConstructor - Free and Opensource CAM for Linux and Mac
4 years 3 weeks ago - 4 years 3 weeks ago #253479 by phillc54
Attached is the test file, I am not sure what you mean by configuration, I am just using the defaults.
I should add that this iMac has a retina screen.
The attached patch makes it quite useable but probably needs more work.
When I refer to plasma I am referring to the plasmac based configurations which are a bit oddball in the linuxcnc way of thing.
For plasma it is best for small holes to have a straight leadin even if other leadins are arcs, and the length of the leadin needs to be restricted to no longer than the hole radius. I would be nice to have a user changeable small hole size size with say a default of 32mm as these holes would also normally set a hal pin to limit the velocity for torch height control.
Plasmac also uses materials in a different way in that we use materials rather than linuxcnc tools, this is not really compatible with the linuxcnc norm...
Last edit: 4 years 3 weeks ago by phillc54.
4 years 3 weeks ago #253505 by meister
@tommylight
i think the transport costs to germany are bigger than a cheap homemade one, but thanks :)
@phillc54
thank you for the patch, i merged it with little changes
about plasma/small holes/...:
i could add more machine->tool-modes for plasma to support such special functions
i have to think about how to integrate this best
if you have any ideas, you can share them with me :)
4 years 3 weeks ago #253596 by meister
i would like to make the prostprocessor more customizable and include functions like:
before_lead_in
before_lead_out
before_begin
after_begin
before_end
after_end
before_contour
before_tab
after_tab
before_island
after_island
before_plunge
after_plunge
What do you think about this and where should you be able to insert your own code ?
3 years 8 months ago #265601 by Dragonick
Are you able to help me?
Via Constructor opens but gives an error.
The dxf file does not open either
3 years 8 months ago #265639 by meister
please replace 'PATH_TO_DXF' with the real path to your .dxf file you want to open.
3 years 7 months ago #265668 by Dragonick
I ran only with the command: python3.9 -m via constructor, because I don't know how to change it.
and the program opens, but when I load the dxf file, nothing is displayed.
Time to create page: 0.746 seconds
