ViaConstructor - Free and Opensource CAM for Linux and Mac
3 years 7 months ago #265717 by phillc54
For X on Wayland you can try one of these depending on the gui toolkit you are using:
export PYOPENGL_PLATFORM="x11"
export GDK_BACKEND="x11"
export QT_QPA_PLATFORM="xcb"
3 years 7 months ago #265718 by Dragonick
could you tell me where should i put it?
3 years 7 months ago #265746 by phillc54
Enter the command in a terminal prior to running ViaConstructor.
ViaConstructor is Qt so you may only require the QT.. command.
3 years 7 months ago #265772 by Dragonick
when i type it i get this message.
ViaConstructor opens but still not working properly
QStandardPaths: runtime directory '/run/user/1000' is not owned by UID 0, but a directory permissions 0700 owned by UID 1000 GID 1000
Error creating proxy: The connection is closed (g-io-error-quark, 18)
(viaconstructor:1826): dconf-WARNING **: 05:11:16.564: failed to commit changes to dconf: The connection is closed
3 years 7 months ago #265773 by phillc54
That looks to me like you are trying to run it as the root user, you should normally run applications as a normal user.
3 years 7 months ago #265793 by Dragonick
Yes you are right. I run as root.
when I enter as a user, the messages do not appear, but the 3d visualization still does not work
Time to create page: 0.325 seconds
