How to create profile for path that is not closed loop
23 Oct 2025 20:50 #337010 by Routerworks
I have to ask one last question. I have been working with Inkscape to develop g codes from and svg drawing. Works great and would like to use for this however I can't get the g code size to match the size in the page. I have looked all over and don't seem to get a clear answer that really works. About ready to give this up, shouldn't be this hard. Must be missing something.
Any comments greatly appreciated.
23 Oct 2025 21:14 #337013 by tommylight
In the upper bar where the dimensions are, set it to whatever you are using, mm or inch, before working on the drawing.
You can open a new empty file, set the mm or inch, and save that as a template, so you open that file first then paste whatever you are working on.
Reminds me of another tip you wont find on the net, when opening any other file type, like PDF, CDR, DXF, HPGL etc, always, always select the drawing with select all (CTRL+A) and open a new Inkscape (CTRL+N) then paste on the new instance with (CTRL+V).
Most of those file types do not contain dimensional info, so makes a mess when exporting them to gcode, the above will save you a lot of headache.
27 Oct 2025 10:43 #337285 by Routerworks
I have to say I tried every scaling combination in the book for Inkscape i.e. px,mm,in and none of them work. I keep getiing g code for an image of 250 inches for a 3 inch be 6 inch drawing. I find I can use inkscape for handling and ungrouping the svg and then import it into freecad. Freecad is much easier to handle and I get very good results.
Inkscape really has to address the conversion situation much better than it has.
Again, thanks for all your help
Time to create page: 0.243 seconds
