img2m67 - Image to M67 Analog Out (PWM) for laser raster
  • rdtsc
  • rdtsc's Avatar Topic Author
  • Senior Member
  • Senior Member
05 Sep 2026 13:36 #349358 by rdtsc
Good day.  I've created a PyQt6 app to convert an image file into rasterized M67 gcode output.  It renders .svg files to 16-bit depth; check it out: github.com/mj1911/img2m67
  • Moderator
  • Moderator
05 Sep 2026 14:58 #349360 by tommylight
Seems interesting, but i have no clue when i'll have some time to test.
I have scratchers i build and use dmap2gcode for it modified to output M67 values, works perfectly fine for my needs, and also works for an UV laser i have collecting dust in the shop (makes to much smoke, unhealthy), so i am interested to see how much the results would improve.
My scratchers:
forum.linuxcnc.org/show-your-stuff/46752...ver-etcher-scratcher
forum.linuxcnc.org/show-your-stuff/37784...-or-any-hard-surface
Time to create page: 0.148 seconds
