LOWPASS Forumla
8 years 3 months ago - 8 years 3 months ago #113666 by BigJohnT
LOWPASS Forumla was created by BigJohnT
In the 2.8 docs for lowpass the following formula is given when you paste the formula into a spreadsheet.
( 1-e^(-2*pi*70*.001) )
However no explanation of what e^ is so I can't complete the formula and match the example so I know if I'm correct or not.
Also on the man page it shows up like this:
( 1-e**(-2*pi*70*.001) )
I assume that is a man page issue and I'll look into that when I return home.
Thanks to who added the examples but I wonder why the examples were not added to the 2.7 documents?
JT
Last edit: 8 years 3 months ago by BigJohnT.
8 years 3 months ago #113669 by PCW
Replied by PCW on topic LOWPASS Forumla
the ^ and ** are both exponentiation operators
so e**n and e^n mean the same thing
( the constant e (2.71828...) raised to the power n )
8 years 3 months ago - 8 years 3 months ago #113673 by BigJohnT
Replied by BigJohnT on topic LOWPASS Forumla
Ah Ha, a little googling and I found this page on e
And now with that bit of information I'm able to complete the equation and it matches Deweys examples.
Thanks Peter
JT
8 years 3 months ago - 8 years 3 months ago #113716 by rodw
Replied by rodw on topic LOWPASS Forumla
Funny, we were both struggling with this at the same time. On another thread, Peter said for a 70 Hz filter the gain was:
PCW wrote: Rod:
0.355849556024592
(assuming 1 KHz sampling)
In my case, I had correctly assumed e = 2.718 but was let down by a crappy calculator on my Chromebook. Once I moved to Google Sheets, it was perfect! Thanks for the tip on spreadsheets John!
It would be good if the docs were updated to state:
where:
e = the mathematical constant 2.71828
and the more normal ^ symbol was used for yn instead of ** (which I've never seen in use)
Last edit: 8 years 3 months ago by rodw.
8 years 3 months ago #113737 by andypugh
Replied by andypugh on topic LOWPASS Forumla
I found this interesting:
softwareengineering.stackexchange.com/qu...ad-of-exponentiation
I think that it was ** in Sinclair basic because the Sinclair character set didn't have ^
If I was in charge I think I might commonise on ** (super-multiplication).
Though that wouldn't work with C, it would have no way to know if a ** b meant "a to the power of b" or "a • the contents of b"
8 years 3 months ago - 8 years 3 months ago #113739 by andypugh
Pi has an infinite number of non-repeating decimal places.
e has an infinite number of non-repeating decimal places.
i is an imaginary number.
Yet e^i.pi = -1
Which is remarkable.
en.wikipedia.org/wiki/Euler's_identity
Last edit: 8 years 3 months ago by andypugh.
Moderators: HansU
Time to create page: 0.226 seconds
