IP Blocked
25 Oct 2024 07:21 #313204 by spontarelliam
Replied by spontarelliam on topic IP Blocked
Ok i just reported it again on my post from the 23rd
25 Oct 2024 08:00 #313210 by tommylight
Replied by tommylight on topic IP Blocked
We got mail, i am not near my PC so will check later as it seems JT was online now.
25 Oct 2024 09:27 #313213 by tommylight
I have unblocked your IP, although having looked at the logs, it will probably be blocked again as it was blocked 4 times in a very short period, for 30 minutes at a time.
You should really check your PC/laptop/phone or whatever you use to login here for malware.
25 Oct 2024 09:46 #313216 by spontarelliam
Thank you, it worked!
Very strange. If I open a web browser that has 10 linuxcnc.org tabs open on it, would all of those loading at once cause issue?
25 Oct 2024 09:59 #313217 by tommylight
Might be, so in settings see if there is something like "load tabs in background" and set it to off.
I use FireFox and usually have 50 to 200 tabs open with mixed content, but i never have issues.
23 Dec 2024 05:57 #317190 by zieluch
Replied by zieluch on topic IP Blocked
Hi can i ask to unblock also my ip. I started to having same problem as described. I was loging recently from several devices like 5 and seems that my ip is blocked right now. Thanks
25 Dec 2024 13:33 #317368 by tommylight
Unblocked your IP, but it wont last, read below please:
No double posting, deleting the other topic.
Blocked IP's are unblocked after 1/2 hour for the first incursion (i think), 2 times in 24h, then permanently.
Did you bother to read the above posts as to how to avoid getting blocked?
Using 5 devices in a short period of time might also be considered by the server as a "brute force attack", and those are usually permanently blocked.
Yeah, i just checked, you have to stop whatever is trying to log in here, you got 6 rolling blocks in a very short time period today.
Time to create page: 0.367 seconds
