Set TTL-signal according to current feed rate
- frankbatzen
07 Jul 2011 06:03 #11208
by frankbatzen
Set TTL-signal according to current feed rate was created by frankbatzen
I have a desktop mill that is to be used for laser welding using EMC2. Is there any way to make EMC2 generate a TTL-signal that is proportional to the current feed rate? The aim would be to downmodulate the laser power in parts of the welding path where the feed rate decreases (in corners, for example).
frankbatzen
frankbatzen
07 Jul 2011 10:44 #11213
Replied by andypugh on topic Re:Set TTL-signal according to current feed rate
A very similar discussion is ongoing here:
www.linuxcnc.org/component/option,com_ku...w/catid,38/id,11063/
