Live tool wear compensation
- grandixximo
- Thank you received: 10
20 Dec 2013 09:08 - 20 Dec 2013 09:10 #41852
by grandixximo
Replied by grandixximo on topic Live tool wear compensation
in halui i don't see nothing comp related.
right now i have created a pin in my kinematics, it has be set to 41 or 42, to calculate the opposite offsets, but if i had something to communicate to this pins, it would be better then setting them up with a custom Mcode, just for the sake of having a more standard g-code
Last edit: 20 Dec 2013 09:10 by grandixximo.
- Thank you received: 4967
20 Dec 2013 19:38 #41868
No, it isn't there.
But if it was there, that is where it would be easiest to add.
Thinking further, the compensation direction is only ever set by the G-code, not anywhere else.
Ideally you would like to re-map G40, G41 and G42 to also set a HAL pin. I don't think that is possible, but you could certainly create a G41.1 that sets a hal pin then issues a G41 command.
Replied by andypugh on topic Live tool wear compensation
No, it isn't there.
Time to create page: 0.094 seconds
