General
General LinuxCNC Questions
RTCP
RTCP
Thank you received: 0
26 Jul 2011 20:41 #11885
by lupo
I am planning to replace the CNC of a 5-axis milling center. Does EMC2 supports RTCP?
Thank you received: 4798
Thank you received: 3
27 Jul 2011 05:09 #11902
by PKM
I guess RTCP stands for Rotation Tool Center Point here. That's what we talked about on the mail list recently, I just forgot the abbreviation.
Yes, EMC2 supports RTCP for 5-axis machining, with 5axiskins module.
27 Jul 2011 06:24 #11906
by PKM
Yes. Probably the realization is different from your machining center, it has extra axis for tool lenght correction.
If you want to check it, start EMC2 and choose config named '5axis'. There's built-in visualisation of 5axis machine tool.
General
RTCP
Time to create page: 0.111 seconds
