how to connect a poti to control F
28 Jul 2011 09:25 #11942
by wbeppler
Elektronik u. Softwareentwicklung
Wolftec GmbH
Wolfgang Beppler
Kratellen 23
DE-78355 Hohenfels-Kalkofen
This email address is being protected from spambots. You need JavaScript enabled to view it.
how to connect a poti to control F was created by wbeppler
hello,
i want to connect anything rotative to set drive-move-speed (G-Code: F) in G1
if it is possible i want to connect a 2nd potentiometer to set speed in G0 mode
but what hardware do i need ? i want to use any rotative, but i do not know a analog-input at my MESA 5i20 or daughterboards
thanks
Wolfgang
thanks
Wolfgang
Wolftec GmbH
Wolfgang Beppler
Kratellen 23
28 Jul 2011 11:56 #11944
by BigJohnT
Replied by BigJohnT on topic Re:how to connect a poti to control F
Which daughter boards do you have?
Feed Override and Spindle Override in the current version are +- only. When 2.5 comes out you can set the percentage directly.
28 Jul 2011 12:06 #11945
by wbeppler
Wolftec GmbH
Wolfgang Beppler
Kratellen 23
Replied by wbeppler on topic Re:how to connect a poti to control F
hi,
i have daughterboards like:
7i37
7i42
7i47
and 7i33
and i habe a parport card and a 5i20
and if i need more, i'll buy it
thanks for help
7i37
7i42
7i47
and 7i33
thanks for help
Wolftec GmbH
Wolfgang Beppler
Kratellen 23
28 Jul 2011 12:22 #11951
by BigJohnT
I'm pretty sure the most common way is to use a small encoder on your panel to change the FO and SO.
I've found an example on the wiki:
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?Spindleoverride
05 Aug 2011 09:12 #12207
by wbeppler
Wolftec GmbH
Wolfgang Beppler
Kratellen 23
thanks, it works !
BUT new question !
first:
i did
net fo-counts halui.feed-override.counts <= hm2_5i20.0.encoder.01.count
and use a encoder.
for others trying the same:
first 2 encoders (passive 3pin, A, B, C) did not work, 1st electronic encoder 4pin (Gnd, Vcc, A, works fine
now:
my speed goes from 100 to 110 to 120... steps by 10. how to do steps by 1 ?
thanks and best regards
wolfgang
BUT new question !
first:
i did
and use a encoder.
now:
wolfgang
Wolftec GmbH
Wolfgang Beppler
Kratellen 23
05 Aug 2011 12:23 #12211
by BigJohnT
Replied by BigJohnT on topic Re:how to connect a pot to control F
Change the scale of halui.spindle-override.scale.
Time to create page: 0.079 seconds
