running from inside a program
- captain chaos
- Thank you received: 3
07 Aug 2011 22:57 #12289
by captain chaos
running from inside a program was created by captain chaos
How do I, after a fault or error, continue to run a program to completion without going back to the start.
07 Aug 2011 23:01 #12290
Replied by andypugh on topic Re:running from inside a program
captain chaos wrote:
However, it does literally start running from that point, so you will normally have to start the spindle and turn on the coolant in the MDI tab before restarting the program.
Also be careful, I have found that you need to left-click the line before right-clicking it, or it sometimes restarts from somewhere else.
You can click on a line in the program listing in the bottom screen pane, then right-click it, and select "run from here"How do I, after a fault or error, continue to run a program to completion without going back to the start.
- captain chaos
07 Aug 2011 23:27 #12291
by captain chaos
Replied by captain chaos on topic Re:running from inside a program
Thanks for that, will it then run to the next coordinate or does the machine need to be joged to a G code coordinate
and run from there.
and run from there.
07 Aug 2011 23:43 #12292
A toolchange is often a good point to pick up from, too.
It will literally run the selected line. The best policy is generally to find a G0, jog to somewhere where the tool can get to the G0 end-point without hitting anything on the way, and then select the G0 and run-from-line.Thanks for that, will it then run to the next coordinate or does the machine need to be joged to a G code coordinate
and run from there.
- captain chaos
08 Aug 2011 06:22 #12296
by captain chaos
Cheers for that I've been down running the machine (table router) and just encountered a problem where I needed to go back a few steps as it would not pick up with the minimal radius in the code. Having a few problems with vibration setting off the limit switches mechanical I think as it seems to run OK on slower speeds. Thanks for all the help.
Time to create page: 0.181 seconds
