Spindle feedback at high spindle speeds
I want to use spindle feedback for my CNC mill for threading and so on.
Now my question:
What is happen if i run spindle speeds around 10000 rpm and my computer is not fast enough to accquire the spindle encoder signals?
Is this ignored by EMC2 or will this be a problem?
cheers
Are you trying to read the encoder with your parallel port or other hardware?
If your not doing spindle synchronized motion I assume it will be ignored...
![:) :)](/media/kunena/emoticons/smile.png)
Yes i want to read the encoder with the parallel port card, i think it will be fast enough at low spindle speed and i hope it will be ignored at high spindle speeds?
The servo have a resolution of 4096 increments per revolution.
ThankĀ“s for replay!
Wolfgang
Do you mean "Resolver" or does it have both?No
i not plan on threading at 10,000 rpm! I want to mill, to thread and to drive the spindle to position while tool changing with the same spindle it is a servo motor with an attached resolver.
[/quote]Yes i want to read the encoder with the parallel port card, i think it will be fast enough at low spindle speed and i hope it will be ignored at high spindle speeds?
[/quote]
What you can probably do is use only the index (Z) as the input to your closed-loop spindle speed control, into one counter-mode single-channel encoder counter, and use the full A/B/Z channels for a separate encoder function linked to motion,spindle.position for rigid tapping etc.
For the closed-loop spindle, try to get the speed as close as you can with FF0 only, then add just enough Igain to hit the speed target. You probably need to leave P and D at zero.
A one shot or maybe better a flip/flop would fix this for the software counter.
It is one resolver who is read by the servo amplifier. The amplifier then gives me an value from 0-4095 and i want to convert it with a peace
of electronic to a quadrature signal and an index pulse.
Wolfgang
That seems like a retrograde step. The 0-4095 is a nice absolute value. What format/interface is it on?
The value is in a binary format with differential line drivers for each bit.
Maybe not the newest standard but servo + amplifier was a gift and so i want to take it.
