m4 code does not enable spindle
15 Aug 2011 06:38 #12495
by idsoft
m4 code does not enable spindle was created by idsoft
Hi everybody.
Then I try to enable spindle by m4 code, signal on LPT port is not set. But the "spindle forward" button in GUI becomes pushed. If I click on it then signal on LPT port going set. M5 code work properly.
What am I doing wrong?
15 Aug 2011 07:26 #12496
Replied by cmorley on topic Re:m4 code does not enable spindle
Did you set a speed ? s100 for instance.
15 Aug 2011 07:50 #12497
by idsoft
Replied by idsoft on topic Re:m4 code does not enable spindle
Thank you. Problem is solved.
