Another tool table offset question
- Thank you received: 4967
Have you seen thread.gmane.org/gmane.linux.distributions.emc.devel/6891 ?Is any work being done to include wear offsets or assignable offsets in Linux CNC..
I don't think that the patch has been included in Master, though I believe that it could be.
- SRT
This is great thanks. Where do I go to learn about patches? Using 2.5 Version now.
"man patch"
But you also need to be able to build LinuxCNC from source, so it's not a trivial undertaking.
wiki.linuxcnc.org/cgi-bin/wiki.pl?git
- SRT
I take it I just don't add the features = 64 line to my ini file.
No in 2.5
Possibly in Master. But I don't know if the patch has been accepted. (the problem is that no-one feels they have enough knowledge to accept patches)
- SRT
We are using the patch from the Link above and it works great. This is a very handy patch to LinuxCNC. I would like to see the wear offset table changed to accept diameter values but it is a great patch that moves LinuxCNC closer to a commercial control.
Where is the best place to suggest changes that lean more to the industrial commercial side of this industry. Owning a machine shop and just recently finishing our first LinuxCNC retrofit on a Turning Center we are just now starting a list that is "different" than we are used to. We have been running Fagor, Cincinnati, Fanuc and Mitsubishi controls and they are all a little different but handle certain things like wear offsets in a similar manner.
Possibly on the developers mailing list.Where is the best place to suggest changes that lean more to the industrial commercial side of this industry.
