Start from here -not working
- M4MazakUser
- Thank you received: 3
26 Aug 2011 22:15 #12763
by M4MazakUser
Start from here -not working was created by M4MazakUser
is there anyway to get the "start from here" function working? my lathe has a front and rear turret, if im using any of the rear turret tools in a program, (the rear turret being in "-" values) i get an alarm telling me that the program exceeds the machines limits.
-even though the program will run without a hitch! (from start to fin).
-any ideas/
-any ideas/
27 Aug 2011 11:40 #12771
by ArcEye
Replied by ArcEye on topic Re:Start from here -not working
Hi
What happens when you change your axis min and max (soft limits) for the X axis so that the figures are within the limits?
For instance setting
[AXIS_0]
MIN_LIMIT = -9999
MAX_LIMIT = 9999
negates any soft limits (unless you have a colossal lathe) and should allow you to enter any figure you want for X and EMC will try to go there.
To use 'Start from here' left click on the line you want to highlight it and then right click and select start from here or whatever the wording is.
The code will start from next linear move and you have to run up spindle, select coolant etc before doing so, it won't do it for you like some controllers do.
[AXIS_0]
MIN_LIMIT = -9999
MAX_LIMIT = 9999
27 Aug 2011 12:20 #12773
by BigJohnT
Replied by BigJohnT on topic Re:Start from here -not working
The exceeds machine limits warning is a bug in 2.5 Axis that has been fixed AFAIK. Are you using 2.5?
It had me totally confused for a long time as I have a Run button on my Hardinge that uses halui.program.run and it does not do the limits check.
Time to create page: 0.096 seconds
