Machine stops after some time
- SaqibAdeel
28 Aug 2011 00:17 #12778
by SaqibAdeel
Machine stops after some time was created by SaqibAdeel
Hi Everyone
I recenty ready a milling machine with motenc lite card. All the functions working perfectly. But in auto mode after some time machine stops with no error message appear and spindle still in running position. Can any one help me regarding this problem.
One more thing, i am using TKEMC interface and machine does not show any error message at startup like "unexpected real time delay". plz help me
28 Aug 2011 20:48 #12795
Replied by andypugh on topic Re:Machine stops after some time
Is it a servo or stepper machine?
What stops? Do the drives go free, or is it just motion that stops?
Does the noise the machine makes change at all?
Does dmesg say anything? (type dmesg in a terminal window)
- SaqibAdeel
29 Aug 2011 00:02 #12799
by SaqibAdeel
Replied by SaqibAdeel on topic Re:Machine stops after some time
Its a servo system. when i Run g-code in Auto mode, the machine stops after some time. There is no fix time in which machine stops. Also the drive are engaged and the spindle is still runs. None of the error is displayed at this time.
One more thing. In this condition when i press STEP then RESUME buttons. MAchine restart from last position. Then after some time again machine is stopped.
29 Aug 2011 00:58 #12801
Do you have a hardware pause or feed-hold button?
can you attach your HAL file to a message?
- SaqibAdeel
29 Aug 2011 06:40 #12809
by SaqibAdeel
No Sir, dont have pause button. below is a attached files
- SaqibAdeel
29 Aug 2011 06:43 #12810
by SaqibAdeel
Sorry sir, attach files are here
29 Aug 2011 12:16 #12814
Nothing strange there.
Which version of EMC2 are you running?
does dmesg say anything interesting?
29 Aug 2011 14:02 #12816
by BigJohnT
Replied by BigJohnT on topic Re:Machine stops after some time
If you run your g code file in the Axis simulator does it run all the way through?
Is it a huge file?
Is it a huge file?
- SaqibAdeel
29 Aug 2011 19:24 #12826
by SaqibAdeel
I am using Ubuntu 10.4 live CD, which i downloaded from linuxcnc.org. Ok sir i will send you the report which is get after applying dmesg. One more thing, i was tried no. of computer. But the result is same, i mean machine stops after some time.
- SaqibAdeel
29 Aug 2011 19:30 #12828
by SaqibAdeel
No sir, i never try Axis environment. And its not a big file. It is in some KB.
