Machine stops after some time
29 Aug 2011 19:53 #12832 by BigJohnT
Can you attach the g code file to a message?
30 Aug 2011 00:03 - 30 Aug 2011 00:05 #12839 by SaqibAdeel
G-code file is attached here
File Name: TEST.ngc
File Size:54 KB
Last edit: 30 Aug 2011 00:05 by SaqibAdeel.
31 Aug 2011 15:16 - 31 Aug 2011 18:57 #12874 by BigJohnT
It runs to the M30 on my tests.
Last edit: 31 Aug 2011 18:57 by BigJohnT. Reason: totally wrong answer
04 Sep 2011 08:07 #12949 by SaqibAdeel
So where is the problem on my site? At this point I am fed up. Please help me:( .
04 Sep 2011 08:26 #12950 by cncbasher
i would suggest looking towards the pc , for such things as bios settings and or power save modes hard drive power down , stop etc , as emc shows no error messages
alternativey it could be power supply related to the machine , also are limit switches etc sheilded , noise pick up could also cause this .
one check you could do is to disable the spindle motor , and run the program as see if it still stops , if this shows that the program runs then you most likely have noise pickup from the motor running
and need some sheilding on input cables etc .
see how you go
tracking down intermittent problems can be exausting work ...
Time to create page: 0.061 seconds
