M67 Problem
  • Kap1eC
  • Kap1eC's Avatar Topic Author
  • Visitor
  • Visitor
01 Sep 2011 17:41 #12896 by Kap1eC
Replied by Kap1eC on topic Re:M67 Problem
Ok. Thanks.
I haven’t this EMC config in home. Tomorrow I post HAL files.
01 Sep 2011 18:07 #12898 by BigJohnT
Replied by BigJohnT on topic Re:M67 Problem
Kap1eC wrote:
Every M68 command stops motors, but I need continuous motion with analog output control.
May be something ideas?
I try to use free axis as analog signal (for example B axis). I changes value in digital output with commands M62\M63. In moments, when value changes I takes coordinate of axis B.
This is work. Motors moves without stops, but speed is less that I wrote in G code.
All moves on the same line will be coordinated (all arrive at the end point at the same time) so all will slow to slowest axis in the move.
05 Sep 2011 01:02 #12969 by andypugh
Replied by andypugh on topic Re:M67 Problem
Kap1eC wrote:
I want to change laser power during his movement. Value of power need take from G code file. Any ideas?
How are you doing with this?
I have raised a bug report on M67 not working, and I have had a look at the source code.
I actually think that I could fix it, if you are prepared to patch and recompile EMC2?
06 Sep 2011 22:44 #13010 by andypugh
And, thanks to Pavel (and not to me) M67 now works in the 2.5 branch. This will be released as an upgrade soon, but if you can't wait then you should be able to get the new version as a package (no need to compile) from the buildbot tomorrow. (it builds a new version every night, I believe)
buildbot.linuxcnc.org
I just checked, and it missed the current build, so leave it a couple of days.
  • Kap1eC
  • Visitor
  • Visitor
07 Sep 2011 12:37 - 07 Sep 2011 12:40 #13027 by Kap1eC
Real thanks. I'll try to upgrade emc to 2.5 version soon.
I also increased max acceleration. Speed is normal now :P
Last edit: 07 Sep 2011 12:40 by Kap1eC.
  • Kap1eC
  • Visitor
  • Visitor
23 Sep 2011 13:27 #13392 by Kap1eC
I haven't update EMC yet. Does the M67 command work in EMC v 2.5 now? :) It's no problem with this version or it's better to wait for the official release?
23 Sep 2011 13:47 #13393 by andypugh
There is a trial release of EMC2 2.5, but I don't know where to find it (my work web-access blocks buildbot.linuxcnc as malware!)
I would say just pull the 2.5 from buildbot, it is very nearly a production release now, and the M67 patch is in there.
Time to create page: 0.073 seconds
