EMC2 send error. Latency test not run...
02 Sep 2011 01:42 - 02 Sep 2011 01:49 #12901
by mjospina
EMC2 send error. Latency test not run... was created by mjospina
When try to run EMC2, send error msg, attached... The LATENCY TEST do not make any thing.....
Print file information:
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_BIN_DIR=/usr/bin
EMC2_TCL_DIR=/usr/share/emc/tcl
EMC2_SCRIPT_DIR=
EMC2_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/emc2
EMC2_CONFIG_DIR=
EMC2_LANG_DIR=/usr/share/emc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
EMC2_EMCSH=/usr/bin/wish8.5
EMC2 - 2.4.6
Machine configuration directory is '/home/manuel/emc2/configs/MJO FRESADORA'
Machine configuration file is 'MJO FRESADORA.ini'
INIFILE=/home/manuel/emc2/configs/MJO FRESADORA/MJO FRESADORA.ini
PARAMETER_FILE=emc.var
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=
DISPLAY=axis
NML_FILE=
Starting EMC2...
Starting EMC2 server program: emcsvr
Realtime system did not load
Shutting down and cleaning up EMC2...
Killing task emcsvr, PID=4095
Cleanup done
Debug file information:
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/rtai_hal.ko': -1 Operation not permitted
4095
PID TTY STAT TIME COMMAND
Stopping realtime threads
RTAPI: ERROR: could not open shared memory (errno=2)
HAL: ERROR: rtapi init failed
halcmd: hal_init() failed: -22
NOTE: 'rtapi' kernel module must be loaded
Unloading hal components
ERROR: Module hal_lib does not exist in /proc/modules
ERROR: Module rtapi does not exist in /proc/modules
ERROR: Module rtai_math does not exist in /proc/modules
ERROR: Module rtai_sem does not exist in /proc/modules
ERROR: Module rtai_fifos does not exist in /proc/modules
ERROR: Module rtai_sched does not exist in /proc/modules
ERROR: Module rtai_hal does not exist in /proc/modules
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 2.6.32-122-rtai (root@moses-6core) (gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) ) #rtai SMP Tue Jul 27 12:44:07 CDT 2010 (Ubuntu 2.6.32-122.35.rtai-rtai 2.6.32.11+drm33.2)
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] NSC Geode by NSC
[ 0.000000] Cyrix CyrixInstead
[ 0.000000] Centaur CentaurHauls
[ 0.000000] Transmeta GenuineTMx86
[ 0.000000] Transmeta TransmetaCPU
[ 0.000000] UMC UMC UMC UMC
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009f000 (usable)
[ 0.000000] BIOS-e820: 000000000009f000 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000d2000 - 00000000000d4000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e4000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000002fef0000 (usable)
[ 0.000000] BIOS-e820: 000000002fef0000 - 000000002feff000 (ACPI data)
[ 0.000000] BIOS-e820: 000000002feff000 - 000000002ff00000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000002ff00000 - 000000002ff80000 (usable)
[ 0.000000] BIOS-e820: 000000002ff80000 - 0000000030000000 (reserved)
[ 0.000000] BIOS-e820: 00000000ff800000 - 00000000ffc00000 (reserved)
[ 0.000000] BIOS-e820: 00000000fff00000 - 0000000100000000 (reserved)
[ 0.000000] DMI present.
[ 0.000000] last_pfn = 0x2ff80 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-C7FFF write-protect
[ 0.000000] C8000-EFFFF uncachable
[ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask FE0000000 write-back
[ 0.000000] 1 base 020000000 mask FF0000000 write-back
[ 0.000000] 2 base 02FF80000 mask FFFF80000 uncachable
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] e820 update range: 0000000000002000 - 0000000000006000 (usable) ==> (reserved)
[ 0.000000] Scanning 1 areas for low memory corruption
[ 0.000000] modified physical RAM map:
[ 0.000000] modified: 0000000000000000 - 0000000000002000 (usable)
[ 0.000000] modified: 0000000000002000 - 0000000000006000 (reserved)
[ 0.000000] modified: 0000000000006000 - 000000000009f000 (usable)
[ 0.000000] modified: 000000000009f000 - 00000000000a0000 (reserved)
[ 0.000000] modified: 00000000000d2000 - 00000000000d4000 (reserved)
[ 0.000000] modified: 00000000000e4000 - 0000000000100000 (reserved)
[ 0.000000] modified: 0000000000100000 - 000000002fef0000 (usable)
[ 0.000000] modified: 000000002fef0000 - 000000002feff000 (ACPI data)
[ 0.000000] modified: 000000002feff000 - 000000002ff00000 (ACPI NVS)
[ 0.000000] modified: 000000002ff00000 - 000000002ff80000 (usable)
[ 0.000000] modified: 000000002ff80000 - 0000000030000000 (reserved)
[ 0.000000] modified: 00000000ff800000 - 00000000ffc00000 (reserved)
[ 0.000000] modified: 00000000fff00000 - 0000000100000000 (reserved)
[ 0.000000] initial memory mapped : 0 - 00c00000
[ 0.000000] init_memory_mapping: 0000000000000000-000000002ff80000
[ 0.000000] Using x86 segment limits to approximate NX protection
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 002fc00000 page 2M
[ 0.000000] 002fc00000 - 002ff80000 page 4k
[ 0.000000] kernel direct mapping tables up to 2ff80000 @ 7000-c000
[ 0.000000] RAMDISK: 232ec000 - 23f73d66
[ 0.000000] ACPI: RSDP 000f6da0 00014 (v00 TOSCPL)
[ 0.000000] ACPI: RSDT 2fefa617 0002C (v01 TOSCPL RSDT 06040000 LTP 00000000)
[ 0.000000] ACPI: FACP 2fefef64 00074 (v01 TOSCPL BTR20 06040000 PTL 00000001)
[ 0.000000] ACPI: DSDT 2fefa643 04921 (v01 COMPAL BTR20 06040000 MSFT 0100000D)
[ 0.000000] ACPI: FACS 2fefffc0 00040
[ 0.000000] ACPI: BOOT 2fefefd8 00028 (v01 TOSCPL $SBFTBL$ 06040000 LTP 00000001)
[ 0.000000] 0MB HIGHMEM available.
[ 0.000000] 767MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 2ff80000
[ 0.000000] low ram: 0 - 2ff80000
[ 0.000000] node 0 low ram: 00000000 - 2ff80000
[ 0.000000] node 0 bootmap 00008000 - 0000dff0
[ 0.000000] (9 early reservations) ==> bootmem [0000000000 - 002ff80000]
[ 0.000000] #0 [0000000000 - 0000001000] BIOS data page ==> [0000000000 - 0000001000]
[ 0.000000] #1 [0000001000 - 0000002000] EX TRAMPOLINE ==> [0000001000 - 0000002000]
[ 0.000000] #2 [0000006000 - 0000007000] TRAMPOLINE ==> [0000006000 - 0000007000]
[ 0.000000] #3 [0000100000 - 00008b0db8] TEXT DATA BSS ==> [0000100000 - 00008b0db8]
[ 0.000000] #4 [00232ec000 - 0023f73d66] RAMDISK ==> [00232ec000 - 0023f73d66]
[ 0.000000] #5 [000009f000 - 0000100000] BIOS reserved ==> [000009f000 - 0000100000]
[ 0.000000] #6 [00008b1000 - 00008b40fc] BRK ==> [00008b1000 - 00008b40fc]
[ 0.000000] #7 [0000007000 - 0000008000] PGTABLE ==> [0000007000 - 0000008000]
[ 0.000000] #8 [0000008000 - 000000e000] BOOTMAP ==> [0000008000 - 000000e000]
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000000 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x0002ff80
[ 0.000000] HighMem 0x0002ff80 -> 0x0002ff80
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[4] active PFN ranges
[ 0.000000] 0: 0x00000000 -> 0x00000002
[ 0.000000] 0: 0x00000006 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x0002fef0
[ 0.000000] 0: 0x0002ff00 -> 0x0002ff80
[ 0.000000] On node 0 totalpages: 196363
[ 0.000000] free_area_init_node: node 0, pgdat c07470e0, node_mem_map c1001000
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3963 pages, LIFO batch:0
[ 0.000000] Normal zone: 1503 pages used for memmap
[ 0.000000] Normal zone: 190865 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x1008
[ 0.000000] SMP: Allowing 1 CPUs, 0 hotplug CPUs
[ 0.000000] Local APIC disabled by BIOS -- you can enable it with "lapic"
[ 0.000000] APIC: disable apic facility
[ 0.000000] nr_irqs_gsi: 16
[ 0.000000] Allocating PCI resources starting at 30000000 (gap: 30000000:cf800000)
[ 0.000000] NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:1 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 24 pages/cpu @c1800000 s74936 r0 d23368 u4194304
[ 0.000000] pcpu-alloc: s74936 r0 d23368 u4194304 alloc=1*4194304
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 194828
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-122-rtai root=UUID=47c7b99c-121f-4b2d-a643-3f5a7dcabebd ro quiet splash
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Enabling fast FPU save and restore... done.
[ 0.000000] Enabling unmasked SIMD FPU exception support... done.
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 3929600 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (00000000:00000000)
[ 0.000000] Memory: 753416k/785920k available (4539k kernel code, 31632k reserved, 1928k data, 620k init, 0k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff1e000 - 0xfffff000 ( 900 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf0780000 - 0xff7fe000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xeff80000 ( 767 MB)
[ 0.000000] .init : 0xc0751000 - 0xc07ec000 ( 620 kB)
[ 0.000000] .data : 0xc056ecbc - 0xc0750e68 (1928 kB)
[ 0.000000] .text : 0xc0100000 - 0xc056ecbc (4539 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] SLUB: Genslabs=13, HWalign=128, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:2304 nr_irqs:256
[ 0.000000] I-pipe 2.6-03: pipeline enabled.
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 1993.545 MHz processor.
[ 0.008007] Calibrating delay loop (skipped), value calculated using timer frequency.. 3987.09 BogoMIPS (lpj=7974180)
[ 0.008040] Security Framework initialized
[ 0.008078] AppArmor: AppArmor initialized
[ 0.008093] Mount-cache hash table entries: 512
[ 0.008331] Initializing cgroup subsys ns
[ 0.008339] Initializing cgroup subsys cpuacct
[ 0.008349] Initializing cgroup subsys memory
[ 0.008368] Initializing cgroup subsys devices
[ 0.008374] Initializing cgroup subsys freezer
[ 0.008379] Initializing cgroup subsys net_cls
[ 0.008421] CPU: Trace cache: 12K uops, L1 D cache: 8K
[ 0.008429] CPU: L2 cache: 512K
[ 0.008434] CPU: Hyper-Threading is disabled
[ 0.008442] mce: CPU supports 4 MCE banks
[ 0.008469] Performance Events: no PMU driver, software events only.
[ 0.008484] Checking 'hlt' instruction... OK.
[ 0.025610] SMP alternatives: switching to UP code
[ 0.041529] Freeing SMP alternatives: 31k freed
[ 0.041566] ACPI: Core revision 20090903
[ 0.053209] ACPI: setting ELCR to 0200 (from 0820)
[ 0.056026] ftrace: converting mcount calls to 0f 1f 44 00 00
[ 0.056035] ftrace: allocating 21003 entries in 42 pages
[ 0.073577] Enabling APIC mode: Flat. Using 0 I/O APICs
[ 0.073584] weird, boot CPU (#0) not listed by the BIOS.
[ 0.073587] SMP motherboard not detected.
[ 0.073591] Local APIC not detected. Using dummy APIC emulation.
[ 0.073595] SMP disabled
[ 0.073916] Brought up 1 CPUs
[ 0.073923] Total of 1 processors activated (3987.09 BogoMIPS).
[ 0.074282] CPU0 attaching NULL sched-domain.
[ 0.074532] devtmpfs: initialized
[ 0.075130] regulator: core version 0.5
[ 0.075219] NET: Registered protocol family 16
[ 0.075436] EISA bus registered
[ 0.075451] ACPI: bus type pci registered
[ 0.095222] PCI: PCI BIOS revision 2.10 entry at 0xfd990, last bus=2
[ 0.095227] PCI: Using configuration type 1 for base access
[ 0.096702] bio: create slab <bio-0> at 0
[ 0.097715] ACPI: EC: Look up EC in DSDT
[ 0.103844] ACPI: Interpreter enabled
[ 0.103849] ACPI: (supports S0 S5)
[ 0.103868] ACPI: Using PIC for interrupt routing
[ 0.149389] ACPI: EC: GPE = 0x1c, I/O: command/status = 0x66, data = 0x62
[ 0.149650] ACPI: No dock devices found.
[ 0.150702] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.150774] pci 0000:00:00.0: reg 10 32bit mmio pref: [0xec000000-0xefffffff]
[ 0.151016] pci 0000:00:1f.0: quirk: region 1000-107f claimed by ICH4 ACPI/GPIO/TCO
[ 0.151024] pci 0000:00:1f.0: quirk: region 1180-11bf claimed by ICH4 GPIO
[ 0.151081] pci 0000:00:1f.1: reg 20 io port: [0x1800-0x180f]
[ 0.151156] pci 0000:00:1f.2: reg 20 io port: [0x1820-0x183f]
[ 0.151229] pci 0000:00:1f.3: reg 20 io port: [0x1810-0x181f]
[ 0.151302] pci 0000:00:1f.4: reg 20 io port: [0x1840-0x185f]
[ 0.151351] pci 0000:00:1f.5: reg 10 io port: [0x1c00-0x1cff]
[ 0.151361] pci 0000:00:1f.5: reg 14 io port: [0x1880-0x18bf]
[ 0.151428] pci 0000:00:1f.6: reg 10 io port: [0x2400-0x24ff]
[ 0.151439] pci 0000:00:1f.6: reg 14 io port: [0x2000-0x207f]
[ 0.151530] pci 0000:01:00.0: reg 10 32bit mmio pref: [0xf0000000-0xf7ffffff]
[ 0.151540] pci 0000:01:00.0: reg 14 io port: [0x3000-0x30ff]
[ 0.151549] pci 0000:01:00.0: reg 18 32bit mmio: [0xe8000000-0xe800ffff]
[ 0.151573] pci 0000:01:00.0: reg 30 32bit mmio pref: [0x000000-0x01ffff]
[ 0.151602] pci 0000:01:00.0: supports D1 D2
[ 0.151656] pci 0000:00:01.0: bridge io port: [0x3000-0x3fff]
[ 0.151663] pci 0000:00:01.0: bridge 32bit mmio: [0xe8000000-0xe80fffff]
[ 0.151670] pci 0000:00:01.0: bridge 32bit mmio pref: [0xf0000000-0xf7ffffff]
[ 0.151721] pci 0000:02:00.0: reg 10 32bit mmio: [0x000000-0x000fff]
[ 0.151748] pci 0000:02:00.0: supports D1 D2
[ 0.151753] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.151760] pci 0000:02:00.0: PME# disabled
[ 0.151806] pci 0000:02:00.1: reg 10 32bit mmio: [0x000000-0x000fff]
[ 0.151833] pci 0000:02:00.1: supports D1 D2
[ 0.151837] pci 0000:02:00.1: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.151844] pci 0000:02:00.1: PME# disabled
[ 0.151908] pci 0000:02:08.0: reg 10 32bit mmio: [0xe8104000-0xe8104fff]
[ 0.151918] pci 0000:02:08.0: reg 14 io port: [0x4000-0x403f]
[ 0.151971] pci 0000:02:08.0: supports D1 D2
[ 0.151975] pci 0000:02:08.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.151982] pci 0000:02:08.0: PME# disabled
[ 0.152048] pci 0000:02:0a.0: reg 10 32bit mmio: [0xe8105000-0xe81057ff]
[ 0.152059] pci 0000:02:0a.0: reg 14 32bit mmio: [0xe8100000-0xe8103fff]
[ 0.152114] pci 0000:02:0a.0: supports D1 D2
[ 0.152119] pci 0000:02:0a.0: PME# supported from D0 D1 D2 D3hot
[ 0.152126] pci 0000:02:0a.0: PME# disabled
[ 0.152169] pci 0000:00:1e.0: transparent bridge
[ 0.152176] pci 0000:00:1e.0: bridge io port: [0x4000-0x4fff]
[ 0.152184] pci 0000:00:1e.0: bridge 32bit mmio: [0xe8100000-0xe81fffff]
[ 0.152246] pci_bus 0000:00: on NUMA node 0
[ 0.152255] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.152324] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.AGP_._PRT]
[ 0.152352] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.SLOT._PRT]
[ 0.157470] ACPI: PCI Interrupt Link [LNKA] (IRQs *5)
[ 0.157622] ACPI: PCI Interrupt Link [LNKB] (IRQs *11)
[ 0.157772] ACPI: PCI Interrupt Link [LNKC] (IRQs *11)
[ 0.157921] ACPI: PCI Interrupt Link [LNKD] (IRQs *5)
[ 0.158080] ACPI: PCI Interrupt Link [LNKE] (IRQs *11)
[ 0.158240] ACPI: PCI Interrupt Link [LNKH] (IRQs 5) *11
[ 0.158437] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.158446] vgaarb: loaded
[ 0.158679] SCSI subsystem initialized
[ 0.158815] libata version 3.00 loaded.
[ 0.158949] usbcore: registered new interface driver usbfs
[ 0.158978] usbcore: registered new interface driver hub
[ 0.159027] usbcore: registered new device driver usb
[ 0.159268] ACPI: WMI: Mapper loaded
[ 0.159273] PCI: Using ACPI for IRQ routing
[ 0.159507] NetLabel: Initializing
[ 0.159512] NetLabel: domain hash size = 128
[ 0.159515] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.159544] NetLabel: unlabeled traffic allowed by default
[ 0.159618] Switching to clocksource tsc
[ 0.160001] AppArmor: AppArmor Filesystem Enabled
[ 0.160001] pnp: PnP ACPI init
[ 0.160001] ACPI: bus type pnp registered
[ 0.184387] pnp: PnP ACPI: found 10 devices
[ 0.184393] ACPI: ACPI bus type pnp unregistered
[ 0.184401] PnPBIOS: Disabled by ACPI PNP
[ 0.184422] system 00:01: ioport range 0xfe00-0xfe01 has been reserved
[ 0.184431] system 00:01: ioport range 0x1000-0x107f has been reserved
[ 0.184438] system 00:01: ioport range 0x1180-0x11bf has been reserved
[ 0.184444] system 00:01: ioport range 0x4d0-0x4d1 has been reserved
[ 0.219325] pci 0000:00:01.0: PCI bridge, secondary bus 0000:01
[ 0.219332] pci 0000:00:01.0: IO window: 0x3000-0x3fff
[ 0.219340] pci 0000:00:01.0: MEM window: 0xe8000000-0xe80fffff
[ 0.219347] pci 0000:00:01.0: PREFETCH window: 0xf0000000-0xf7ffffff
[ 0.219371] pci 0000:02:00.0: CardBus bridge, secondary bus 0000:03
[ 0.219375] pci 0000:02:00.0: IO window: 0x004400-0x0044ff
[ 0.219382] pci 0000:02:00.0: IO window: 0x004800-0x0048ff
[ 0.219390] pci 0000:02:00.0: PREFETCH window: 0x30000000-0x33ffffff
[ 0.219397] pci 0000:02:00.0: MEM window: 0x38000000-0x3bffffff
[ 0.219404] pci 0000:02:00.1: CardBus bridge, secondary bus 0000:07
[ 0.219409] pci 0000:02:00.1: IO window: 0x004c00-0x004cff
[ 0.219416] pci 0000:02:00.1: IO window: 0x001400-0x0014ff
[ 0.219423] pci 0000:02:00.1: PREFETCH window: 0x34000000-0x37ffffff
[ 0.219430] pci 0000:02:00.1: MEM window: 0x3c000000-0x3fffffff
[ 0.219438] pci 0000:00:1e.0: PCI bridge, secondary bus 0000:02
[ 0.219444] pci 0000:00:1e.0: IO window: 0x4000-0x4fff
[ 0.219452] pci 0000:00:1e.0: MEM window: 0xe8100000-0xe81fffff
[ 0.219460] pci 0000:00:1e.0: PREFETCH window: 0x30000000-0x37ffffff
[ 0.219487] pci 0000:00:1e.0: setting latency timer to 64
[ 0.219777] ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 5
[ 0.219782] PCI: setting IRQ 5 as level-triggered
[ 0.219790] pci 0000:02:00.0: PCI INT A -> Link[LNKA] -> GSI 5 (level, low) -> IRQ 5
[ 0.219798] pci 0000:02:00.0: setting latency timer to 64
[ 0.220032] ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 11
[ 0.220036] PCI: setting IRQ 11 as level-triggered
[ 0.220043] pci 0000:02:00.1: PCI INT B -> Link[LNKB] -> GSI 11 (level, low) -> IRQ 11
[ 0.220051] pci 0000:02:00.1: setting latency timer to 64
[ 0.220060] pci_bus 0000:00: resource 0 io: [0x00-0xffff]
[ 0.220065] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffff]
[ 0.220070] pci_bus 0000:01: resource 0 io: [0x3000-0x3fff]
[ 0.220075] pci_bus 0000:01: resource 1 mem: [0xe8000000-0xe80fffff]
[ 0.220080] pci_bus 0000:01: resource 2 pref mem [0xf0000000-0xf7ffffff]
[ 0.220085] pci_bus 0000:02: resource 0 io: [0x4000-0x4fff]
[ 0.220090] pci_bus 0000:02: resource 1 mem: [0xe8100000-0xe81fffff]
[ 0.220095] pci_bus 0000:02: resource 2 pref mem [0x30000000-0x37ffffff]
[ 0.220100] pci_bus 0000:02: resource 3 io: [0x00-0xffff]
[ 0.220105] pci_bus 0000:02: resource 4 mem: [0x000000-0xffffffff]
[ 0.220110] pci_bus 0000:03: resource 0 io: [0x4400-0x44ff]
[ 0.220114] pci_bus 0000:03: resource 1 io: [0x4800-0x48ff]
[ 0.220119] pci_bus 0000:03: resource 2 pref mem [0x30000000-0x33ffffff]
[ 0.220124] pci_bus 0000:03: resource 3 mem: [0x38000000-0x3bffffff]
[ 0.220129] pci_bus 0000:07: resource 0 io: [0x4c00-0x4cff]
[ 0.220134] pci_bus 0000:07: resource 1 io: [0x1400-0x14ff]
[ 0.220138] pci_bus 0000:07: resource 2 pref mem [0x34000000-0x37ffffff]
[ 0.220143] pci_bus 0000:07: resource 3 mem: [0x3c000000-0x3fffffff]
[ 0.220207] NET: Registered protocol family 2
[ 0.220399] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.221064] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.222520] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.223450] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.223456] TCP reno registered
[ 0.223709] NET: Registered protocol family 1
[ 0.223806] pci 0000:01:00.0: Boot video device
[ 0.223851] pci 0000:02:08.0: Firmware left e100 interrupts enabled; disabling
[ 0.224057] Simple Boot Flag at 0x36 set to 0x1
[ 0.224243] Scanning for low memory corruption every 60 seconds
[ 0.224488] audit: initializing netlink socket (disabled)
[ 0.224512] type=2000 audit(1314920334.224:1): initialized
[ 0.234316] Trying to unpack rootfs image as initramfs...
[ 0.244713] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.250946] VFS: Disk quotas dquot_6.5.2
[ 0.251055] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.252133] fuse init (API version 7.13)
[ 0.252300] msgmni has been set to 1472
[ 0.256589] alg: No test for stdrng (krng)
[ 0.256752] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.256759] io scheduler noop registered
[ 0.256763] io scheduler anticipatory registered
[ 0.256767] io scheduler deadline registered
[ 0.256841] io scheduler cfq registered (default)
[ 0.257034] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.257079] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.257218] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
[ 0.257330] ACPI: Lid Switch [LID]
[ 0.257409] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 0.257420] ACPI: Power Button [PWBN]
[ 0.257520] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 0.257525] ACPI: Power Button [PWRF]
[ 0.260178] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.260875] serial 0000:00:1f.6: power state changed by ACPI to D0
[ 0.260894] serial 0000:00:1f.6: PCI INT B -> Link[LNKB] -> GSI 11 (level, low) -> IRQ 11
[ 0.260904] serial 0000:00:1f.6: PCI INT B disabled
[ 0.262615] brd: module loaded
[ 0.263447] loop: module loaded
[ 0.263623] input: Macintosh mouse button emulation as /devices/virtual/input/input3
[ 0.263807] ata_piix 0000:00:1f.1: version 2.13
[ 0.263915] ata_piix 0000:00:1f.1: setting latency timer to 64
[ 0.264142] isapnp: Scanning for PnP cards...
[ 0.276645] scsi0 : ata_piix
[ 0.276915] scsi1 : ata_piix
[ 0.278693] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0x1800 irq 14
[ 0.278699] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0x1808 irq 15
[ 0.279414] Fixed MDIO Bus: probed
[ 0.279485] PPP generic driver version 2.4.2
[ 0.279601] tun: Universal TUN/TAP device driver, 1.6
[ 0.279605] tun: (C) 1999-2004 Max Krasnyansky <This email address is being protected from spambots. You need JavaScript enabled to view it.>
[ 0.279780] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.279812] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.279837] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.280175] ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 5
[ 0.280184] uhci_hcd 0000:00:1f.2: PCI INT D -> Link[LNKD] -> GSI 5 (level, low) -> IRQ 5
[ 0.280201] uhci_hcd 0000:00:1f.2: setting latency timer to 64
[ 0.280207] uhci_hcd 0000:00:1f.2: UHCI Host Controller
[ 0.280287] uhci_hcd 0000:00:1f.2: new USB bus registered, assigned bus number 1
[ 0.328534] uhci_hcd 0000:00:1f.2: irq 5, io base 0x00001820
[ 0.328814] usb usb1: configuration #1 chosen from 1 choice
[ 0.328868] hub 1-0:1.0: USB hub found
[ 0.328886] hub 1-0:1.0: 2 ports detected
[ 0.329303] ACPI: PCI Interrupt Link [LNKH] enabled at IRQ 5
[ 0.329311] uhci_hcd 0000:00:1f.4: PCI INT C -> Link[LNKH] -> GSI 5 (level, low) -> IRQ 5
[ 0.329331] uhci_hcd 0000:00:1f.4: setting latency timer to 64
[ 0.329336] uhci_hcd 0000:00:1f.4: UHCI Host Controller
[ 0.329419] uhci_hcd 0000:00:1f.4: new USB bus registered, assigned bus number 2
[ 0.329452] uhci_hcd 0000:00:1f.4: irq 5, io base 0x00001840
[ 0.329615] usb usb2: configuration #1 chosen from 1 choice
[ 0.329664] hub 2-0:1.0: USB hub found
[ 0.329680] hub 2-0:1.0: 2 ports detected
[ 0.329844] PNP: PS/2 Controller [PNP0303:KBC0,PNP0f13:MSE0] at 0x60,0x64 irq 1,12
[ 0.337724] i8042.c: Detected active multiplexing controller, rev 1.1.
[ 0.340365] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.340387] serio: i8042 AUX0 port at 0x60,0x64 irq 12
[ 0.340473] serio: i8042 AUX1 port at 0x60,0x64 irq 12
[ 0.340520] serio: i8042 AUX2 port at 0x60,0x64 irq 12
[ 0.340563] serio: i8042 AUX3 port at 0x60,0x64 irq 12
[ 0.340832] mice: PS/2 mouse device common for all mice
[ 0.341175] rtc_cmos 00:04: rtc core: registered rtc_cmos as rtc0
[ 0.341201] rtc0: alarms up to one month, y3k, 114 bytes nvram
[ 0.341432] device-mapper: uevent: version 1.0.3
[ 0.343641] device-mapper: ioctl: 4.15.0-ioctl (2009-04-01) initialised: This email address is being protected from spambots. You need JavaScript enabled to view it.
[ 0.345110] device-mapper: multipath: version 1.1.0 loaded
[ 0.345118] device-mapper: multipath round-robin: version 1.0.0 loaded
[ 0.347076] EISA: Probing bus 0 at eisa.0
[ 0.347089] Cannot allocate resource for EISA slot 1
[ 0.347095] Cannot allocate resource for EISA slot 2
[ 0.347099] Cannot allocate resource for EISA slot 3
[ 0.347103] Cannot allocate resource for EISA slot 4
[ 0.347123] EISA: Detected 0 cards.
[ 0.347129] cpuidle: using governor ladder
[ 0.347133] cpuidle: using governor menu
[ 0.347878] TCP cubic registered
[ 0.348100] NET: Registered protocol family 10
[ 0.348918] lo: Disabled Privacy Extensions
[ 0.349474] NET: Registered protocol family 17
[ 0.349537] Using IPI No-Shortcut mode
[ 0.349729] registered taskstats version 1
[ 0.350080] rtc_cmos 00:04: setting system clock to 2011-09-01 23:38:55 UTC (1314920335)
[ 0.350087] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 0.350091] EDD information not available.
[ 0.358120] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
[ 0.521707] ata2.00: ATAPI: UJDA730 DVD/CDRW, 1.00, max UDMA/33
[ 0.521948] ata1.00: ATA-5: IC25N040ATCS04-0, CA4OA71A, max UDMA/100
[ 0.521954] ata1.00: 78140160 sectors, multi 16: LBA
[ 0.537455] ata2.00: configured for UDMA/33
[ 0.538271] ata1.00: configured for UDMA/100
[ 0.952426] isapnp: No Plug & Play device found
[ 0.952681] scsi 0:0:0:0: Direct-Access ATA IC25N040ATCS04-0 CA4O PQ: 0 ANSI: 5
[ 0.952997] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 0.953280] sd 0:0:0:0: [sda] 78140160 512-byte logical blocks: (40.0 GB/37.2 GiB)
[ 0.953378] sd 0:0:0:0: [sda] Write Protect is off
[ 0.953384] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 0.953433] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 0.953706] sda:
[ 0.956486] scsi 1:0:0:0: CD-ROM MATSHITA UJDA730 DVD/CDRW 1.00 PQ: 0 ANSI: 5
[ 0.964465] sr0: scsi3-mmc drive: 24x/24x writer cd/rw xa/form2 cdda tray
[ 0.964476] Uniform CD-ROM driver Revision: 3.20
[ 0.964703] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 0.964822] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 0.969352] sda1 sda2 < sda5 >
[ 1.000980] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.174176] Freeing initrd memory: 12831k freed
[ 1.198568] Freeing unused kernel memory: 620k freed
[ 1.199774] Write protecting the kernel text: 4540k
[ 1.199817] Write protecting the kernel read-only data: 1668k
[ 1.243430] udev: starting version 151
[ 1.654818] Floppy drive(s): fd0 is 1.44M
[ 1.655067] Linux agpgart interface v0.103
[ 1.682395] agpgart-intel 0000:00:00.0: Intel 845G Chipset
[ 1.687727] FDC 0 is a post-1991 82077
[ 1.689739] agpgart-intel 0000:00:00.0: AGP aperture is 64M @ 0xec000000
[ 1.740792] [drm] Initialized drm 1.1.0 20060810
[ 1.746903] e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI
[ 1.746911] e100: Copyright(c) 1999-2006 Intel Corporation
[ 1.747299] ACPI: PCI Interrupt Link [LNKE] enabled at IRQ 11
[ 1.747308] e100 0000:02:08.0: PCI INT A -> Link[LNKE] -> GSI 11 (level, low) -> IRQ 11
[ 1.771815] e100 0000:02:08.0: PME# disabled
[ 1.801759] e100: eth0: e100_probe: addr 0xe8104000, irq 11, MAC addr 00:02:3f:7b:e0:30
[ 1.802112] ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 11
[ 1.802121] ohci1394 0000:02:0a.0: PCI INT A -> Link[LNKC] -> GSI 11 (level, low) -> IRQ 11
[ 1.847836] [drm] radeon defaulting to kernel modesetting.
[ 1.847843] [drm] radeon kernel modesetting enabled.
[ 1.847935] radeon 0000:01:00.0: PCI INT A -> Link[LNKA] -> GSI 5 (level, low) -> IRQ 5
[ 1.852440] [drm] radeon: Initializing kernel modesetting.
[ 1.852599] [drm] register mmio base: 0xE8000000
[ 1.852604] [drm] register mmio size: 65536
[ 1.854377] [drm] GPU reset succeed (RBBM_STATUS=0x00000140)
[ 1.854413] agpgart-intel 0000:00:00.0: AGP 2.0 bridge
[ 1.854439] agpgart-intel 0000:00:00.0: putting AGP V2 device into 4x mode
[ 1.854471] radeon 0000:01:00.0: putting AGP V2 device into 4x mode
[ 1.854507] [drm] radeon: VRAM 64M
[ 1.854511] [drm] radeon: VRAM from 0x00000000 to 0x03FFFFFF
[ 1.854514] [drm] radeon: GTT 64M
[ 1.854518] [drm] radeon: GTT from 0xEC000000 to 0xEFFFFFFF
[ 1.854550] [drm] radeon: irq initialized.
[ 1.854718] [drm] Detected VRAM RAM=64M, BAR=128M
[ 1.854725] [drm] RAM width 64bits DDR
[ 1.854866] [TTM] Zone kernel: Available graphics memory: 383650 kiB.
[ 1.854896] [drm] radeon: 16M of VRAM memory ready
[ 1.854901] [drm] radeon: 64M of GTT memory ready.
[ 1.865114] ohci1394: fw-host0: OHCI-1394 1.1 (PCI): IRQ=[11] MMIO=[e8105000-e81057ff] Max Packet=[2048] IR/IT contexts=[4/8]
[ 1.866451] [drm] radeon: cp idle (0x00008080)
[ 1.866518] [drm] Loading R100 Microcode
[ 1.866857] platform radeon_cp.0: firmware: requesting radeon/R100_cp.bin
[ 1.879973] [drm] radeon: ring at 0x00000000EC000000
[ 1.880008] [drm] ring test succeeded in 1 usecs
[ 1.885484] [drm] radeon: ib pool ready.
[ 1.885617] [drm] ib test succeeded in 0 usecs
[ 1.886571] [drm] Panel ID String: 1024x768
[ 1.886577] [drm] Panel Size 1024x768
[ 1.886738] [drm] Default TV standard: NTSC
[ 1.886743] [drm] 27.000000000 MHz TV ref clk
[ 1.886748] [drm] Default TV standard: NTSC
[ 1.886751] [drm] 27.000000000 MHz TV ref clk
[ 1.886848] [drm] Radeon Display Connectors
[ 1.886853] [drm] Connector 0:
[ 1.886856] [drm] VGA
[ 1.886861] [drm] DDC: 0x60 0x60 0x60 0x60 0x60 0x60 0x60 0x60
[ 1.886865] [drm] Encoders:
[ 1.886868] [drm] CRT1: INTERNAL_DAC1
[ 1.886872] [drm] Connector 1:
[ 1.886874] [drm] LVDS
[ 1.886877] [drm] Encoders:
[ 1.886880] [drm] LCD1: INTERNAL_LVDS
[ 1.886883] [drm] Connector 2:
[ 1.886886] [drm] S-video
[ 1.886889] [drm] Encoders:
[ 1.886892] [drm] TV1: INTERNAL_DAC2
[ 1.948729] [drm] fb mappable at 0xF0040000
[ 1.948736] [drm] vram apper at 0xF0000000
[ 1.948740] [drm] size 786432
[ 1.948743] [drm] fb depth is 8
[ 1.948746] [drm] pitch is 1024
[ 1.949012] fb0: radeondrmfb frame buffer device
[ 1.949017] registered panic notifier
[ 1.949028] [drm] Initialized radeon 2.0.0 20080528 for 0000:01:00.0 on minor 0
[ 1.953926] vga16fb: initializing
[ 1.953936] vga16fb: mapped to 0xc00a0000
[ 1.953944] vga16fb: not registering due to another framebuffer present
[ 2.034622] Console: switching to colour frame buffer device 128x48
[ 2.581069] xor: automatically using best checksumming function: pIII_sse
[ 2.600025] pIII_sse : 2595.000 MB/sec
[ 2.600030] xor: using function: pIII_sse (2595.000 MB/sec)
[ 2.628371] device-mapper: dm-raid45: initialized v0.2594b
[ 2.918464] EXT4-fs (sda1): mounted filesystem with ordered data mode
[ 3.136252] ieee1394: Host added: ID:BUS[0-00:1023] GUID[00023f2920006cb7]
[ 20.214821] udev: starting version 151
[ 20.256193] Adding 732152k swap on /dev/sda5. Priority:-1 extents:1 across:732152k
[ 20.375118] lp: driver loaded but no devices found
[ 20.435561] intel_rng: FWH not detected
[ 20.565393] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 20.992154] parport_pc 00:09: reported by Plug and Play ACPI
[ 20.992188] parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE,EPP]
[ 21.072607] lp0: using parport0 (interrupt-driven).
[ 21.208186] ppdev: user-space parallel port driver
[ 21.212874] yenta_cardbus 0000:02:00.0: CardBus bridge found [1179:ff00]
[ 21.212904] yenta_cardbus 0000:02:00.0: O2: res at 0x94/0xD4: e8/00
[ 21.212909] yenta_cardbus 0000:02:00.0: Yenta O2: old bridge, disabling read prefetch/write burst
[ 21.249233] input: PS/2 Mouse as /devices/platform/i8042/serio4/input/input5
[ 21.265513] input: AlpsPS/2 ALPS GlidePoint as /devices/platform/i8042/serio4/input/input6
[ 21.340559] yenta_cardbus 0000:02:00.0: ISA IRQ mask 0x0418, PCI irq 5
[ 21.340567] yenta_cardbus 0000:02:00.0: Socket status: 30000820
[ 21.340575] pci_bus 0000:02: Raising subordinate bus# of parent bus (#02) from #02 to #06
[ 21.340594] yenta_cardbus 0000:02:00.0: pcmcia: parent PCI bridge I/O window: 0x4000 - 0x4fff
[ 21.340601] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x4000-0x4fff: clean.
[ 21.341399] yenta_cardbus 0000:02:00.0: pcmcia: parent PCI bridge Memory window: 0xe8100000 - 0xe81fffff
[ 21.341405] yenta_cardbus 0000:02:00.0: pcmcia: parent PCI bridge Memory window: 0x30000000 - 0x37ffffff
[ 21.352826] yenta_cardbus 0000:02:00.1: CardBus bridge found [1179:ff00]
[ 21.402412] type=1505 audit(1314920356.549:2): operation="profile_load" pid=571 name="/sbin/dhclient3"
[ 21.403243] type=1505 audit(1314920356.549:3): operation="profile_load" pid=571 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 21.403711] type=1505 audit(1314920356.549:4): operation="profile_load" pid=571 name="/usr/lib/connman/scripts/dhclient-script"
[ 21.480562] yenta_cardbus 0000:02:00.1: ISA IRQ mask 0x0418, PCI irq 11
[ 21.480571] yenta_cardbus 0000:02:00.1: Socket status: 30000006
[ 21.480579] pci_bus 0000:02: Raising subordinate bus# of parent bus (#02) from #06 to #0a
[ 21.480598] yenta_cardbus 0000:02:00.1: pcmcia: parent PCI bridge I/O window: 0x4000 - 0x4fff
[ 21.480605] pcmcia_socket pcmcia_socket1: cs: IO port probe 0x4000-0x4fff: clean.
[ 21.481004] yenta_cardbus 0000:02:00.1: pcmcia: parent PCI bridge Memory window: 0xe8100000 - 0xe81fffff
[ 21.481011] yenta_cardbus 0000:02:00.1: pcmcia: parent PCI bridge Memory window: 0x30000000 - 0x37ffffff
[ 21.785290] Intel ICH 0000:00:1f.5: power state changed by ACPI to D0
[ 21.785309] Intel ICH 0000:00:1f.5: PCI INT B -> Link[LNKB] -> GSI 11 (level, low) -> IRQ 11
[ 21.785339] Intel ICH 0000:00:1f.5: setting latency timer to 64
[ 21.962787] type=1505 audit(1314920357.109:5): operation="profile_load" pid=689 name="/usr/share/gdm/guest-session/Xsession"
[ 21.969075] type=1505 audit(1314920357.117:6): operation="profile_replace" pid=690 name="/sbin/dhclient3"
[ 21.969948] type=1505 audit(1314920357.117:7): operation="profile_replace" pid=690 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 21.970432] type=1505 audit(1314920357.117:8): operation="profile_replace" pid=690 name="/usr/lib/connman/scripts/dhclient-script"
[ 21.988083] pcmcia_socket pcmcia_socket0: pccard: CardBus card inserted into slot 0
[ 21.988133] pci 0000:03:00.0: reg 10 32bit mmio: [0x000000-0x001fff]
[ 22.000210] type=1505 audit(1314920357.149:9): operation="profile_load" pid=691 name="/usr/bin/evince"
[ 22.019854] b43-pci-bridge 0000:03:00.0: enabling device (0000 -> 0002)
[ 22.019876] b43-pci-bridge 0000:03:00.0: PCI INT A -> Link[LNKA] -> GSI 5 (level, low) -> IRQ 5
[ 22.019894] b43-pci-bridge 0000:03:00.0: setting latency timer to 64
[ 22.033522] ssb: Sonics Silicon Backplane found on PCI device 0000:03:00.0
[ 22.069688] type=1505 audit(1314920357.217:10): operation="profile_load" pid=691 name="/usr/bin/evince-previewer"
[ 22.146009] type=1505 audit(1314920357.293:11): operation="profile_load" pid=691 name="/usr/bin/evince-thumbnailer"
[ 22.213729] cfg80211: Calling CRDA to update world regulatory domain
[ 22.270747] cfg80211: World regulatory domain updated:
[ 22.270755] (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 22.270761] (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 22.270766] (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 22.270772] (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 22.270777] (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 22.270781] (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 22.352772] pcmcia_socket pcmcia_socket1: cs: IO port probe 0x100-0x3af: excluding 0x200-0x20f
[ 22.354811] pcmcia_socket pcmcia_socket1: cs: IO port probe 0x3e0-0x4ff: clean.
[ 22.355698] pcmcia_socket pcmcia_socket1: cs: IO port probe 0x820-0x8ff: clean.
[ 22.372723] pcmcia_socket pcmcia_socket1: cs: IO port probe 0xc00-0xcf7: clean.
[ 22.373748] pcmcia_socket pcmcia_socket1: cs: IO port probe 0xa00-0xaff: clean.
[ 22.399428] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x100-0x3af: excluding 0x200-0x20f
[ 22.401914] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x3e0-0x4ff: clean.
[ 22.402802] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x820-0x8ff: clean.
[ 22.403544] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xc00-0xcf7: clean.
[ 22.436633] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xa00-0xaff: clean.
[ 22.466999] b43-phy0: Broadcom 4306 WLAN found (core revision 5)
[ 22.518308] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 22.652483] phy0: Selected rate control algorithm 'minstrel'
[ 22.653727] Registered led device: b43-phy0::tx
[ 22.653762] Registered led device: b43-phy0::rx
[ 22.653802] Registered led device: b43-phy0::radio
[ 22.653938] Broadcom 43xx driver loaded [ Features: PL, Firmware-ID: FW13 ]
[ 22.732169] b43 ssb0:0: firmware: requesting b43/ucode5.fw
[ 22.784170] b43 ssb0:0: firmware: requesting b43/pcm5.fw
[ 22.794539] b43 ssb0:0: firmware: requesting b43/b0g0initvals5.fw
[ 22.813805] b43 ssb0:0: firmware: requesting b43/b0g0bsinitvals5.fw
[ 23.112072] intel8x0_measure_ac97_clock: measured 55302 usecs (2658 samples)
[ 23.112079] intel8x0: clocking to 48000
[ 23.221740] b43-phy0: Loading firmware version 410.2160 (2007-05-26 15:32:10)
[ 23.360700] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 54.212237] wlan0: deauthenticating from f0:7d:68:42:22:68 by local choice (reason=3)
[ 54.212727] wlan0: direct probe to AP f0:7d:68:42:22:68 (try 1)
[ 54.218111] wlan0: direct probe responded
[ 54.218122] wlan0: authenticate with AP f0:7d:68:42:22:68 (try 1)
[ 54.219718] wlan0: authenticated
[ 54.219764] wlan0: associate with AP f0:7d:68:42:22:68 (try 1)
[ 54.223590] wlan0: RX AssocResp from f0:7d:68:42:22:68 (capab=0xc31 status=0 aid=2)
[ 54.223598] wlan0: associated
[ 54.235048] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 54.235144] cfg80211: Calling CRDA for country: US
[ 54.243917] cfg80211: Received country IE:
[ 54.243926] cfg80211: Regulatory domain: US
[ 54.243930] (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 54.243936] (2402000 KHz - 2477000 KHz @ 40000 KHz), (10000 mBi, 10000 mBm)
[ 54.243940] cfg80211: CRDA thinks this should applied:
[ 54.243943] cfg80211: Regulatory domain: US
[ 54.243946] (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 54.243951] (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2700 mBm)
[ 54.243957] (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 1700 mBm)
[ 54.243963] (5250000 KHz - 5330000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 54.243969] (5490000 KHz - 5600000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 54.243974] (5650000 KHz - 5710000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 54.243979] (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 3000 mBm)
[ 54.243982] cfg80211: We intersect both of these and get:
[ 54.243986] cfg80211: Regulatory domain: 98
[ 54.243989] (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 54.243994] (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2700 mBm)
[ 54.244071] cfg80211: Disabling channel 2467 MHz on phy0 due to Country IE
[ 54.244076] cfg80211: Disabling channel 2472 MHz on phy0 due to Country IE
[ 54.244080] cfg80211: Disabling channel 2484 MHz on phy0 due to Country IE
[ 54.244086] cfg80211: Current regulatory domain updated by AP to: US
[ 54.244090] (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 54.244095] (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2700 mBm)
[ 55.401039] padlock: VIA PadLock not detected.
[ 64.348033] wlan0: no IPv6 routers present
[ 155.605976] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 1518.391996] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 1522.023927] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 1531.868332] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 1883.344549] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 1896.572959] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 1898.316319] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 1901.185532] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 1902.841010] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 1904.444745] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 2006.758717] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 2010.593452] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 2546.651275] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 2702.826618] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 2908.409986] wlan0: deauthenticating from f0:7d:68:42:22:68 by local choice (reason=3)
[ 2934.289238] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 3159.286597] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 3367.050879] wlan0: deauthenticating from f0:7d:68:42:22:68 by local choice (reason=3)
[ 3367.232180] wlan0: direct probe to AP f0:7d:68:42:22:68 (try 1)
[ 3367.238013] wlan0: direct probe responded
[ 3367.238024] wlan0: authenticate with AP f0:7d:68:42:22:68 (try 1)
[ 3367.240256] wlan0: authenticated
[ 3367.240315] wlan0: associate with AP f0:7d:68:42:22:68 (try 1)
[ 3367.243631] wlan0: RX AssocResp from f0:7d:68:42:22:68 (capab=0xc31 status=0 aid=2)
[ 3367.243639] wlan0: associated
[ 6177.248155] hub 1-0:1.0: unable to enumerate USB device on port 2
[ 6198.560059] end_request: I/O error, dev fd0, sector 0
[ 6335.140049] end_request: I/O error, dev fd0, sector 0
[ 6351.056050] end_request: I/O error, dev fd0, sector 0
[ 6829.616856] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 6918.364957] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_SCRIPT_DIR=
EMC2_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
EMC2 - 2.4.6
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=
DISPLAY=axis
NML_FILE=
Starting EMC2...
Cleanup done
4095
[ 0.953706] sda:
Last edit: 02 Sep 2011 01:49 by mjospina.
02 Sep 2011 03:12 #12902
Replied by PCW on topic Re:EMC2 send error. Latency test not run...
I'm afraid you have the dreaded lapic error:
This may help:
wiki.linuxcnc.org/emcinfo.pl?TroubleShoo..._t_run_missing_lapic
This may help:
Time to create page: 0.087 seconds
