4 Axes Machine Questions
15 years 1 month ago #13524 by andypugh
Todd Zuercher wrote:
I tried it and received the error
Debug file information:
core_stepper.hal:32: Pin 'axis.2.motor-pos-cmd' was already linked to signal 'Zpos-cmd'
7643
Ah, yes.
In that case, you probably need to use "linkps"
halcmd unlinkp axis.3.motor-pos-cmd
halcmd linkps axis.3.motor-pos-cmd Zpos-cmd
And
halcmd linkps axis.3.motor-pos-cmd Apos-cmd
(except, of course, that I just told you to delsig Apos-cmd, so you will need to restart the config to recreate it)
I am shooting from the hip here, I have never tried this.
15 years 1 month ago - 15 years 1 month ago #13525 by andypugh
Did you "short circuit" the stepgen feedback?
(I should have said, the feedback from the stepgen just reports that the pulse generator can keep up with the commanded speed, so is semi-optional)
Last edit: 15 years 1 month ago by andypugh.
15 years 1 month ago #13539 by Todd Zuercher
If you are talking about changing this line
net Apos-fb stepgen.3.position-fb => axis.3.motor-pos-fb
to
net Zpos-fb stepgen.2.position-fb => axis.3.motor-pos-fb
Yes I tried that. and it had no effect.
But I did notice that while I have the net Apos-cmd axis.3.motor-pos-cmd => stepgen.3.position-cmd line short circuited, when I try to jog it does move the A axis, just a tiny amount before it gives the joint 3 error. Is there a way to cut this off further upstream, so that what ever is seeing the error sees this as a commanded movement instead of an error?
15 years 1 month ago #13540 by andypugh
to
No, that's not really what I had in mind.
The feedback loops shouldn't change and can be: (check the pin names, I am at work)
net Z-fb axis.2.motor-pos-fb <= stepgen.2.motor-pos-fb
net A-cmd axis.3.motor-pos-cmd => axis.3.motor-pos-fb # Short circuit
The Z command stays the same at all times.
net Z-cmd axis.2.motor-pos-cmd => stepgen.2.position
Now, to link motor 3 to the Z axis:
net Z-cmd axis.3.motor-pos-cmd
And to make it follow the A-word in the G-code
(Again, all untried and untested)
11 years 1 month ago - 11 years 1 month ago #62481 by Todd Zuercher
Now to dredge up an old thread.
I think I've finally mostly solved this! :woohoo:
I made two custom M-codes (M122 and M123) that temporarily slave the movement of the W axis to the Z.
It works with both a stepper config (in simulation at least) and I have it running on a servo machine as well.
One bug that I still have to squash though is that while slaved the following error of the W isn't monitored. No big deal for a stepper system, but a little scary with a servo. I have some ideas but have not taken the time to implement them yet.
Here is the stepper config as an example for others to look at. (The M-code files need to be located in the right place to work as well.)
Last edit: 11 years 1 month ago by Todd Zuercher.
11 years 1 month ago #62747 by Todd Zuercher
Ok, I think I have a feedback system in place for my servo configuration.
What I did is to use sum2 to add (subtract actually) the axis.8.motor-pos-cmd and the PID error for the W axis. Feeding that to the mux2 that short circuits the W feedback while operating in ZZ mode.
It seems to work ok now, but the very first time I started the config, it did a false runaway on the W axis when I switched to ZZ mode (numbers on the DRO were moving but the motor wasn't). After a restarting Linuxcnc it has behaved fine. (Fingers crossed)
Attached is the servo config.
The following user(s) said Thank You: akb1212
Time to create page: 0.391 seconds
