Re:ini. changes while EMC2 running?
- cwebs
- Rick G
- Thank you received: 114
Rick G
Can I make changes to my ini file while the program is running? I will be making changes to MAX_ACCELERATION rate. Or will I have to stop, restart, home and try the change? Thanks Carl
Changes you make to the INI file will have no effect while the program is running.
However, you can change pins and parameters if you want. (but the changes will not be mirrored in the iNI file)
The way to do it is using the halcmd setp (set parameter/pin) command. You can type this command either into a terminal window (with EMC2 running) or into the box at the bottom of the machine->show hal config window in Axis or tkEMC. (You might have to re-size the window to even see the box)
I prefer to use a terminal, because then you get tab-completion and history.
I can't actually find any pins/paramters for axis accelleration though, which is annoying.
If you are tuning your axes with a stepper system then one way is to create a dummy stepgen config, and experiment in the "test axis" mode, then make a note of the values for your INI file.
- cwebs
- Rick G
www.linuxcnc.org/docs/EMC2_Getting_Started.pdf
Section 7 on Stepconfig
As Andy said that is an easy place to experiment with changes, and of course be sure to make a new machine set up so as not to overwrite your existing working machine.
Where did the configuration you are using now come from? It might be that it is already optimized for your machine.
When experimenting with acceleration and velocity find the limits and then back off them to avoid stalls/lost steps when you are actually working.
Rick G
- step4linux
- Thank you received: 5
I was also looking for this, but some parameters of the ini file seems are not visible as hal-pins or parameters, neither in documentation nor in hal-meter nor in hal-file you can see it.
Good question: where are they hidden ?
Is there any other access possible ?
Gerd
git.linuxcnc.org/gitweb?p=emc2.git;a=blo...c/emc/ini/iniaxis.cc
Which is in
git.linuxcnc.org/gitweb?p=emc2.git;a=blo...emc/task/taskintf.cc
and uses
emcmotCommand.command = EMCMOT_SET_JOINT_ACC_LIMIT
Which is ony used in command.c.
command.c has some very interesting comments related to this question at the beginning.
git.linuxcnc.org/gitweb?p=emc2.git;a=blo...emc/motion/command.c
- cwebs
- Rick G
Rick G
- grijalvap
- Thank you received: 63
