Re:ini. changes while EMC2 running?
15 years 1 month ago #13020 by andypugh
It seems that the value goes straight from the INI file to emcAxisSetMaxAcceleration in
git.linuxcnc.org/gitweb?p=emc2.git;a=blo...c/emc/ini/iniaxis.cc
Which is in
git.linuxcnc.org/gitweb?p=emc2.git;a=blo...emc/task/taskintf.cc
and uses
emcmotCommand.command = EMCMOT_SET_JOINT_ACC_LIMIT
Which is ony used in command.c.
command.c has some very interesting comments related to this question at the beginning.
git.linuxcnc.org/gitweb?p=emc2.git;a=blo...emc/motion/command.c
15 years 1 month ago #13107 by cwebs
Unable to increase the Acceleration but the G61 and G64P works for me. Thanks guys. Carl
15 years 1 month ago #13108 by Rick G
Glad to hear you have it working now.
Rick G
1 year 1 month ago #334891 by grijalvap
Any update?
1 year 1 month ago #334894 by Aciera
ini values can be changed using the 'ini.*' hal pins. Changes can be made while a program is running but will only become active after a queue buster command (eg M66 E0 L0) which will restart the motion planner with the updated ini values.
Time to create page: 0.355 seconds
