Computer lock up with emc + ethercat
- Deotti
12 Sep 2011 00:46 #13115
by Deotti
Computer lock up with emc + ethercat was created by Deotti
Hi everyone !
I have emc2 integrated with Ethercat (Etherlab.org), running a Beckhoff AX5000 servo driver performing
a very nice system. But if axis backplot is enable after some minutes running
the computer lock up, if i disable the backplot it run for more than 10 hours before lock up.
Someone have an idea what causes this problem?
I am using EMC 2.4.6 with Axis interface.
- Thank you received: 4992
12 Sep 2011 12:31 #13123
Replied by andypugh on topic Re:Computer lock up with emc + ethercat
Deotti wrote:
This sounds like an OpenGL problem.
You might find that software-only OpenGL helps:
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?Tro...oftware_based_OpenGL
- Deotti
16 Sep 2011 01:20 #13219
by Deotti
Replied by Deotti on topic Re:Computer lock up with emc + ethercat
Thanks for help me !
I have installed the library like recomended but the problem persists.
I'm testing emc2 with the standard program that came with Axis but i
have entered a loop repeat [50] to run it for many hours.
Am i exaggerating running a program for to many hours?
One machine that we made is working for more than one year 18 hours
a day without problems, but executing small programs repeatedly.
16 Sep 2011 11:54 #13223
Deotti wrote:
It shouldn't be a problem.
You could try puttingbefore the loop-end label so that the preview only runs once.
linuxcnc.org/docs/html/gui_axis.html#r1_11_7
But that shouldn't be necessary.
(AXIS, hide)
- Deotti
27 Sep 2011 01:24 #13467
by Deotti
One more time thanks for help me !
Your clue made my processor working less.
But you won't belive what was causing the lock up.
I was using an wireless mouse and keyboard, last week , i removed
it and connected a wired one and Bingo!
My system is running for 4 days without lock.
I had no idea that it could hapen.
- Coyote
12 Nov 2012 08:48 #26468
by Coyote
Replied by Coyote on topic Re:Computer lock up with emc + ethercat
Dear Deotti,
Can you post a source code of the driver for AX5000, or some advice where to start?
Thank you
Thank you
Time to create page: 0.078 seconds
