Strange error: Bad character 'a' used
- GreenPlease
15 Sep 2011 02:10 - 15 Sep 2011 02:13 #13205
by GreenPlease
Strange error: Bad character 'a' used was created by GreenPlease
Hey guys
I'm really new to all of this so please bear with me. When I try to open up a .ngc file in EMC2 I get an error that says:
G-Code error in FirstCut.ngc
Near line 12 of /home/cornelius/Desktop/FirstCut.ngc
I'm not sure if this is a problem with the .ngc file created by meshcam or if it's a problem with EMC2. Also, after I click "ok" in the dialog box nothing loads and I'm just left with a blank workspace. I don't see toolpaths or any of the geometry that I saw in Meshcam or Inventor.
Right now my software chain goes Autodesk Inventor -> .stl file -> Meshcam -> .ngc file -> EMC2. Any help would be much appreciated.
PS I'm posting the same question over on the Meshcam forum as well
Last edit: 15 Sep 2011 02:13 by GreenPlease.
- jmelson
- Thank you received: 160
15 Sep 2011 04:28 #13206
by jmelson
Replied by jmelson on topic Re:Strange error: Bad character 'a' used
GreenPlease wrote:
Jon
Can you post the first 15 lines of this G-code file?
Jon
- Thank you received: 5013
15 Sep 2011 15:55 #13212
Replied by andypugh on topic Re:Strange error: Bad character 'a' used
GreenPlease wrote:
If your machine _does_ have an A axis, then the problem is in the INI file. Look for a line saying COORDINATES and add A to the list.
This would be a very odd problem to find on a machine which was configured by stepconf, though. Is this a hand-built machine config?
This error means that you are using an "A" word on a machine which does not have an A-axis.Bad character 'a' used
- BigJohnT
- Thank you received: 1176
15 Sep 2011 20:26 #13217
by BigJohnT
Replied by BigJohnT on topic Re:Strange error: Bad character 'a' used
This error will occur anytime an "a" is found when not expected even if it is not used as an axis.
G4 a
will produce it.
G4 a
will produce it.
