Camera working only sometime
- grandixximo
- Thank you received: 10
12 Oct 2011 13:33 - 18 Oct 2011 03:25 #13865
by grandixximo
Camera working only sometime was created by grandixximo
I have follow the step instruction to use a camera with EMC2, using camview-emc
wiki.linuxcnc.org/emcinfo.pl?Axis_Embed_Video
I have a big problem, after sometime the camera is on, it freeze and how i fix it now is:
open camview and make all settings again, then replace the settings "camviewcfg.xml" file, i have notice that the only thing that change in the the file after save is the address
from
input4vl:1
to
input4vl:0
So now when camera freeze, i just need to open the file and change 1 to 0 or viceversa, because it freeze both ways, but after i change it's fine for sometime.
Another very big issue is that the camera when is in freeze state, is saving a log with errors in var\log and in emc debug file, this log files become so big that my 60GB hard disk was full in maybe 1 or 2 hours working.
how can i solve this problem?
from
input4vl:1
to
input4vl:0
Last edit: 18 Oct 2011 03:25 by grandixximo.
- grandixximo
18 Oct 2011 03:18 #14002
by grandixximo
Replied by grandixximo on topic Re:Camera working only sometime
psha is not around?
I think he is the one who can fix this right?
Hope to hear something from him soon.
- eslavko
- Thank you received: 4
18 Oct 2011 14:09 #14023
by eslavko
Replied by eslavko on topic Re:Camera working only sometime
I use that without problem. Just have wrong colorspace (Reed come blue on screen but other work perfect)
thank's psha...
..and psha is (was, I didn't check now) active on IRC
thank's psha...
Time to create page: 0.063 seconds
