emcrsh: server part locks up
26 Oct 2011 08:14 #14271 by ArcEye
Replied by ArcEye on topic Re:emcrsh: server part locks up
Hi jpka,
Glad you got things working, perseverance will out in the end.
Just a bit of extra info.
The timing of the set wait none did appear to be important in some further testing I did.
If left until later in the startup sequence, instead of just after set enable EMCTOO I would sometimes get a
SET WAIT NAK return.
Did not cause a lock up on those occasions, but I did not do too much thereafter, so could have been a problem later.
Keep plugging away
26 Oct 2011 15:56 #14308 by dgarrett
Replied by dgarrett on topic Re:emcrsh: server part locks up
To specify a path for files, this worked for me (emc2.5~pre):
$ emcrsh --path path_to_files/ -- -ini path_to_inifile
the trailing slash (/) on path_to_files is required
i suspect this behavior is same in 2.4
27 Oct 2011 09:42 #14325 by ArcEye
Hi Dewey
Yeah I had picked up on that thanks
....It defaults to ../../nc_files unless launched with the --path switch.
Can only guess that the [DISPLAY] PROGRAM_PREFIX = tag in the .ini file was not present when emcrsh was originally written and given that the --path switch existed and worked, there was no attempt to change things in later revisions.
Time to create page: 0.070 seconds
