Automating Odd Mechanisms
- semi_lucid
18 Oct 2011 19:32 #14032
by semi_lucid
Automating Odd Mechanisms was created by semi_lucid
Hello
I have a question about solar tracking mechanisms.
There are basically two types of solar trackers. The first type has some sort of sensor that detects the sun, and follows it.
The second type is programmed to follow a mathematically determined path, and does not use a sensor.
The first type does not require precision motion control, the motors just respond to the commands from the sensors.
The second type does require precision motion control.
So when designing the mechanism, it occurred to me that the rotational motion of the axes needs to be proportional the the rotation of the motors.This is not necessarily the case with the first type.
I was hoping you would look at the unit in the link below, and tell me how he could be achieving precision motion control with the hinging linear actuator that he's using. Would that require an encoder on the pivot point?
www.solartronenergy.com/solarbeam/galler...concentrator-photos/
Thanks.
Thanks.
- cncbasher
- Thank you received: 288
18 Oct 2011 21:16 #14037
by cncbasher
Replied by cncbasher on topic Re:Automating Odd Mechanisms
it's all to do with following the azimuth satellite path , and in the offset arc inherant in the mounting , they usualy rely on the signal strength to check alignment and an internal counter in the program
at time of setting up , and do nothing more than count pulses
- Thank you received: 4967
18 Oct 2011 21:52 #14041
Replied by andypugh on topic Re:Automating Odd Mechanisms
semi_lucid wrote:
You could so it with an encoder on the motor and a kinematics which matches the linkage.
EMC can solve the equations of motion of robot arms, that solar concentrator would be relatively easy.
www.linuxcnc.org/docview/html/motion_kinematics.html
- semi_lucid
19 Oct 2011 06:20 #14045
by semi_lucid
Replied by semi_lucid on topic Re:Automating Odd Mechanisms
andypugh wrote:
I understand. Thanks for the reply.
Time to create page: 0.058 seconds
