Manipulators?
- eai
24 Oct 2011 10:02 #14155
by eai
Manipulators? was created by eai
Can EMC2 drive manipulators?
Something like this
www.abb.com/cawp/abbzh254/fcfbdad9a72cfe08c1257862006bcfbf.aspx
Something like this
- Thank you received: 5016
24 Oct 2011 10:24 #14157
Replied by andypugh on topic Re:Manipulators?
Yes:
For example.
That particular device would be a bit more challenging as it has two end-effectors. In theory you could use XYZ for one effector and UVW for the other, but that would require a custom kinematics module. You might also need to change the number of joints supported by EMC2 which is fairly hard-coded at 9 at the moment, but there is a branch which is attempting to remove that limit.
With the standard EMC installation I think you would need a separate PC and EMC2 for each side of the robot.
For example.
- eai
24 Oct 2011 10:35 #14158
by eai
Replied by eai on topic Re:Manipulators?
Cool!
Time to create page: 0.073 seconds
