I'm thinking about switching back to EMC (EMC2)
24 Nov 2011 15:17 #15083 by Harry_Y
andypugh wrote:
I thought about a relay before but then dismissed it because I did not want to have to flip a switch
but if EMC can pull a pin High depending on the loaded profile then I'm all set.
One config Uses a HAL file with "setp parport.0.pin-16-out 1" and the other has "setp parport.0.pin-16-out 0"
(Actually, it probably isn't pin 16, I don't even know if pin 16 is an output)
I will have to dig through the manual, but you have put me on the right path.
Thank you
24 Nov 2011 15:49 #15084 by BigJohnT
24 Nov 2011 17:04 #15086 by Harry_Y
Time to create page: 0.069 seconds
