Freeze up on tool change
25 Oct 2011 18:01 #14241 by jeff_HATC
Freeze up on tool change was created by jeff_HATC
I am using 2.4.7 and any updates that Ubuntu has needed.
Every time I issue a Tx M6...the interface just freezes and does nothing.
Tried Axis and Mini GUI's and both are doing the same.
The program gets to the tool change line and just sits there and says "running".
For now, I will just comment the line out...but it has been very fustrating.
25 Oct 2011 19:15 #14245 by BigJohnT
Replied by BigJohnT on topic Re:Freeze up on tool change
Is this a manual tool change?
25 Oct 2011 20:34 #14253 by jeff_HATC
Replied by jeff_HATC on topic Re:Freeze up on tool change
Yes John it is a manual tool change.
I can use an M00 to get the job done, but I am teaching students and want to them to learn how it would be done in a real enviromnet.
25 Oct 2011 23:12 #14260 by BigJohnT
Depending on how you set up your config you need a tool change loop. This is how the tool change loop is done.
www.linuxcnc.org/docview/html/hal_hal-examples.html#r1_1
26 Oct 2011 10:27 #14277 by kostas
Replied by kostas on topic Re:Freeze up on tool change
Had the same problem a few days ago. I *think* that it was because of an empty tool table, or a tool that didn't exist in the tool table.
But I'm not sure, I try to do this again now in my test machine and it does not freeze ..
26 Oct 2011 11:41 #14282 by BigJohnT
Calling a tool that is not in the tool table will throw an error.
26 Oct 2011 15:12 #14306 by andypugh
Replied by andypugh on topic Re:Freeze up on tool change
You can get this if (for some reason) the tool-change dialog pops up in the background. It's worth moving the Axis window to look...
26 Oct 2011 16:07 #14309 by jeff_HATC
Tool was in the table, no error.....just sits there.
The manual tool change code was the answer to the problem.
It took me awhile to figure out what/where this hal file is. Especiall confusing since when I installed the new EMC2 2.4.7 instead of whiping out all the orginal stuff, it kept it. Now every time I run the emc or config, it wants to make the changes to the OLD EMC files not the new. Very confusing.
Time to create page: 0.059 seconds
