g1 z1.0 angle5
- tenaja
- Thank you received: 5
29 Oct 2011 00:32 #14356
by tenaja
g1 z1.0 angle5 was created by tenaja
Is there an angle setting for the g1 commands? On some of my large "commercial" lathes, I can do this...
g0 z0 x1.0
g1 z1.0 a5.0
...and it will do a 1" long, 5* angle cut. I'd like to do this with EMC, but haven't seen it in the Help. It makes chamfers easy, and angled lathe cuts math-free.
Thanks.
g0 z0 x1.0
g1 z1.0 a5.0
Thanks.
- BigJohnT
- Thank you received: 1175
29 Oct 2011 12:55 #14374
by BigJohnT
Replied by BigJohnT on topic Re:g1 z1.0 angle5
- tenaja
01 Nov 2011 16:43 #14491
by tenaja
Replied by tenaja on topic Re:g1 z1.0 angle5
Dang! Looks like it is time to upgrade my EMC...I'm running 2.3.
I actually saw that section on polar coordinates, but the description didn't sound like what I wanted. I will upgrade and give it a try.
Thanks, John.
Thanks, John.
- tenaja
01 Nov 2011 19:07 #14496
by tenaja
Well, my update went ok, but the Polar Move commands fail. Since I am on a lathe, I am using G18 for the XZ plane. When I try to run the angle, I get the error:
Cannot use polar coordinate except in G17 plane.
I guess I will have to wait for it to be implemented for lathes.
- BigJohnT
02 Nov 2011 00:03 #14499
by BigJohnT
Oh, you didn't mention you were running a lathe. Have you seen ngcgui? I use it on my lathe for 95% of my stuff... look in the subroutines section. I think my OD Taper is in there.
- Thank you received: 4892
02 Nov 2011 13:17 #14512
Replied by andypugh on topic Re:g1 z1.0 angle5
tenaja wrote:
You might have a long wait unless you push. I would be tempted to report it as a bug in the bug tracker (or maybe a feature request)
www.linuxcnc.org/content/view/48/13/lang,en/
- BigJohnT
02 Nov 2011 13:44 #14514
by BigJohnT
Polar coordinates are only allowed in the XY plane iiuc... so it would be a feature request.
Polar Coordinates can be used to specify the XY coordinate of a move.
