joystick 2.4.7
  • Rick G
  • Rick G's Avatar Topic Author
  • Junior Member
  • Junior Member
31 Oct 2011 08:31 #14453 by Rick G
joystick 2.4.7 was created by Rick G
John,
Thanks for the heads up, sure saved some time looking for the problem...
I'm not sure what changed but on my plasma when I upgraded to 2.4.7 something changed the input.0.btn-trigger to input.0.btn-joystick...
Ran into the same thing here.
Any idea if this be changed back, or is this permanent?
Rick G
31 Oct 2011 15:07 #14468 by BigJohnT
Replied by BigJohnT on topic Re:joystick 2.4.7
I suspect it to be a permanent thing as far as permanent is.
  • Rick G
  • Junior Member
  • Junior Member
01 Nov 2011 10:33 #14480 by Rick G
Replied by Rick G on topic Re:joystick 2.4.7
Perhaps there was a good reason, otherwise it seems strange to rename a pin that will require users to edit custom configs just to upgrade.
I would kinda hope it was just a bug and would revert.
Rick G
01 Nov 2011 11:53 #14482 by BigJohnT
I don't think it was an EMC thing but rather an Ubuntu update that came at the same time...
  • Rick G
  • Junior Member
  • Junior Member
02 Nov 2011 09:00 #14507 by Rick G
For what it is worth I have one machine running 10.04 on it I have...
EMC 2.4.5 installed and also EMC 2.6.0~pre RIP
The 2.4.5 uses input.0.btn-trigger
The 2.6.0 uses input.0.btn-joystick
Rick G
02 Nov 2011 11:49 #14509 by BigJohnT
I must have been more confused than I thought then... hmmm was it something like expanded support for input?
Your right it was this commit by Seb, or at least he said so I think...
git.linuxcnc.org/gitweb?p=emc2.git;a=com...69f5806255ed5fd309e9
teach linux_event.py about new input events
The Linux Input subsystem has gained some new events since linux_event.py
was written. This commit adds support for the new event types.
This patch is from Przemek Klosowski, thanks!
But I'll be dammed if I can find btn-trigger or btn-joystick in the commit... Some things just elude me.
  • Rick G
  • Junior Member
  • Junior Member
03 Nov 2011 10:21 #14538 by Rick G
From...
git.linuxcnc.org/gitweb?p=emc2.git;a=blo...69f5806255ed5fd309e9
565 'BTN_JOYSTICK': 0x120,
566 'BTN_TRIGGER': 0x120,
Does one replace the other?
Rick G
03 Nov 2011 13:01 #14544 by andypugh
Replied by andypugh on topic Re:joystick 2.4.7
Rick G wrote:
From...
Rick G
That looks like it might be an error.
I think you might be able to just edit the file and see if the names change (Python is interpreted). I would experiment with a totally random name first to see if it is acted on, then try keeping only one of those lines.
03 Nov 2011 13:36 #14547 by BigJohnT
That is odd, I see one other button pair with the same hex number. And looking back at the original commit it is the same.
Time to create page: 0.083 seconds
