RTAI Latency error popup with D525MW
  • questi
  • questi's Avatar Topic Author
  • Visitor
  • Visitor
18 Nov 2011 02:25 - 18 Nov 2011 02:28 #14910 by questi
RTAI Latency error popup with D525MW was created by questi
Hi all
I took the advice and purchased an Intel D525MW motherboard. I just got it today, hooked everything up and stuff.
I turned off hyperthreading in the BIOS. I added a line in the GRUB2 for isolcpus=1. Now I am getting jitter of around 5000, which looks great.
However when I start EMC2 Axis itself, there is always a warning popup on the bottom right that says there is problems with RTAI latency. Why is this?
I can move the motors, but I havent milled anything yet to confirm if it works. What may be the problem?
Is it the SMI? The thing with that is when I follow the instructions, and modified the file, I cant open EMC2 as it gives the error screen. How do you disable SMI? I installed everything from the EMC2 Ubuntu 10.04 LiveCD supplied on this site.
No extra hardware added. Just the vanilla stuff like usb keyboard and mouse.
I also read about someone updating BIOS to get parport working? Do I need to do this?
Last edit: 18 Nov 2011 02:28 by questi.
18 Nov 2011 13:00 #14917 by andypugh
Replied by andypugh on topic Re:RTAI Latency error popup with D525MW
That is unusual. (and disappointing).
If you type "dmesg" in a terminal window and look at the output you will see a more detailed description of the problem. Can you post that segment here?
Have you run the latency test? It would be useful to know if it is a one-time error or not. (the error message only appears once, even if there are frequent latency spikes.
Is it the SMI?
No. There have been no reports of SMI problems with the Atom boards.
I managed to provoke a latency problem with my D510 with a particular webcam.
That shouldn't be necessary. EMC2 has been made to work around a glitch in the EPP-capability reporting of these boards.
18 Nov 2011 14:12 #14920 by BigJohnT
Replied by BigJohnT on topic Re:RTAI Latency error popup with D525MW
Did you run a memtest?
  • questi
  • Visitor
  • Visitor
18 Nov 2011 18:07 #14930 by questi
Replied by questi on topic Re:RTAI Latency error popup with D525MW
In the past when I get the RTAI error, like with my laptop or my gaming PC, I am completely unable to move the motors. Here, I am able to move the motors.
Below is my error message. I will run a MEMtest later. My RAM is from my laptop and I think higher clock speed than the one in the motherboard specs require which is DDR3 800.
[ 0.196505] bio: create slab <bio-0> at 0
[ 0.213319] ACPI: EC: Look up EC in DSDT
[ 0.233929] ACPI: BIOS _OSI(Linux) query ignored
[ 0.234966] ACPI: Interpreter enabled
[ 0.234973] ACPI: (supports S0 S5)
[ 0.234994] ACPI: Using IOAPIC for interrupt routing
[ 0.262799] ACPI: No dock devices found.
[ 0.263172] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.263305] pci 0000:00:02.0: reg 10 32bit mmio: [0xe0200000-0xe027ffff]
[ 0.263315] pci 0000:00:02.0: reg 14 io port: [0x30c0-0x30c7]
[ 0.263324] pci 0000:00:02.0: reg 18 32bit mmio pref: [0xd0000000-0xdfffffff]
[ 0.263332] pci 0000:00:02.0: reg 1c 32bit mmio: [0xe0100000-0xe01fffff]
[ 0.263446] pci 0000:00:1b.0: reg 10 64bit mmio: [0xe0280000-0xe0283fff]
[ 0.263510] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.263518] pci 0000:00:1b.0: PME# disabled
[ 0.263615] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.263623] pci 0000:00:1c.0: PME# disabled
[ 0.263723] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[ 0.263731] pci 0000:00:1c.1: PME# disabled
[ 0.263830] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[ 0.263838] pci 0000:00:1c.2: PME# disabled
[ 0.263935] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[ 0.263942] pci 0000:00:1c.3: PME# disabled
[ 0.264060] pci 0000:00:1d.0: reg 20 io port: [0x3080-0x309f]
[ 0.264158] pci 0000:00:1d.1: reg 20 io port: [0x3060-0x307f]
[ 0.264250] pci 0000:00:1d.2: reg 20 io port: [0x3040-0x305f]
[ 0.264327] pci 0000:00:1d.3: reg 20 io port: [0x3020-0x303f]
[ 0.264411] pci 0000:00:1d.7: reg 10 32bit mmio: [0xe0284400-0xe02847ff]
[ 0.264485] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.264493] pci 0000:00:1d.7: PME# disabled
[ 0.264725] pci 0000:00:1f.2: reg 10 io port: [0x30b8-0x30bf]
[ 0.264736] pci 0000:00:1f.2: reg 14 io port: [0x30cc-0x30cf]
[ 0.264748] pci 0000:00:1f.2: reg 18 io port: [0x30b0-0x30b7]
[ 0.264759] pci 0000:00:1f.2: reg 1c io port: [0x30c8-0x30cb]
[ 0.264770] pci 0000:00:1f.2: reg 20 io port: [0x30a0-0x30af]
[ 0.264781] pci 0000:00:1f.2: reg 24 32bit mmio: [0xe0284000-0xe02843ff]
[ 0.264813] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.264821] pci 0000:00:1f.2: PME# disabled
[ 0.264884] pci 0000:00:1f.3: reg 20 io port: [0x3000-0x301f]
[ 0.264985] pci 0000:01:00.0: reg 10 io port: [0x2000-0x20ff]
[ 0.265016] pci 0000:01:00.0: reg 18 64bit mmio pref: [0xe0004000-0xe0004fff]
[ 0.265039] pci 0000:01:00.0: reg 20 64bit mmio pref: [0xe0000000-0xe0003fff]
[ 0.265104] pci 0000:01:00.0: supports D1 D2
[ 0.265108] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.265118] pci 0000:01:00.0: PME# disabled
[ 0.265212] pci 0000:00:1c.0: bridge io port: [0x2000-0x2fff]
[ 0.265227] pci 0000:00:1c.0: bridge 64bit mmio pref: [0xe0000000-0xe00fffff]
[ 0.265472] pci 0000:05:00.0: reg 10 io port: [0x1030-0x1037]
[ 0.265484] pci 0000:05:00.0: reg 14 io port: [0x1028-0x102f]
[ 0.265497] pci 0000:05:00.0: reg 18 io port: [0x1020-0x1027]
[ 0.265509] pci 0000:05:00.0: reg 1c io port: [0x1018-0x101f]
[ 0.265521] pci 0000:05:00.0: reg 20 io port: [0x1010-0x1017]
[ 0.265533] pci 0000:05:00.0: reg 24 io port: [0x1000-0x100f]
[ 0.265608] pci 0000:00:1e.0: transparent bridge
[ 0.265615] pci 0000:00:1e.0: bridge io port: [0x1000-0x1fff]
[ 0.265659] pci_bus 0000:00: on NUMA node 0
[ 0.265669] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.266012] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P32_._PRT]
[ 0.266235] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX0._PRT]
[ 0.266381] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX1._PRT]
[ 0.266525] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX2._PRT]
[ 0.266670] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX3._PRT]
[ 0.275640] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 7 9 10 *11 12)
[ 0.275855] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 7 9 10 11 12) *0, disabled.
[ 0.284141] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 7 *9 10 11 12)
[ 0.284371] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 7 9 10 *11 12)
[ 0.284582] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 9 *10 11 12)
[ 0.284792] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 7 9 10 11 12) *0, disabled.
[ 0.285004] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 7 *9 10 11 12)
[ 0.285214] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 7 9 *10 11 12)
[ 0.285446] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.285468] vgaarb: loaded
[ 0.285701] SCSI subsystem initialized
[ 0.300103] libata version 3.00 loaded.
[ 0.300306] usbcore: registered new interface driver usbfs
[ 0.300349] usbcore: registered new interface driver hub
[ 0.300408] usbcore: registered new device driver usb
[ 0.308782] ACPI: WMI: Mapper loaded
[ 0.308788] PCI: Using ACPI for IRQ routing
[ 0.309064] NetLabel: Initializing
[ 0.309069] NetLabel: domain hash size = 128
[ 0.309073] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.309096] NetLabel: unlabeled traffic allowed by default
[ 0.309180] Switching to clocksource tsc
[ 0.311998] AppArmor: AppArmor Filesystem Enabled
[ 0.311998] pnp: PnP ACPI init
[ 0.311998] ACPI: bus type pnp registered
[ 0.323744] pnp: PnP ACPI: found 13 devices
[ 0.323751] ACPI: ACPI bus type pnp unregistered
[ 0.323759] PnPBIOS: Disabled by ACPI PNP
[ 0.323782] system 00:01: iomem range 0xf8000000-0xfbffffff has been reserved
[ 0.323790] system 00:01: iomem range 0xfed14000-0xfed17fff has been reserved
[ 0.323797] system 00:01: iomem range 0xfed18000-0xfed18fff has been reserved
[ 0.323804] system 00:01: iomem range 0xfed19000-0xfed19fff has been reserved
[ 0.323811] system 00:01: iomem range 0xfed1c000-0xfed1ffff has been reserved
[ 0.323818] system 00:01: iomem range 0xc0000-0xdffff could not be reserved
[ 0.323825] system 00:01: iomem range 0xe0000-0xfffff could not be reserved
[ 0.323832] system 00:01: iomem range 0xfff00000-0xffffffff has been reserved
[ 0.323847] system 00:06: ioport range 0x500-0x53f has been reserved
[ 0.323854] system 00:06: ioport range 0x400-0x47f has been reserved
[ 0.323861] system 00:06: ioport range 0x680-0x6ff has been reserved
[ 0.323868] system 00:06: ioport range 0x295-0x296 has been reserved
[ 0.387011] pci 0000:00:1c.0: PCI bridge, secondary bus 0000:01
[ 0.387022] pci 0000:00:1c.0: IO window: 0x2000-0x2fff
[ 0.387032] pci 0000:00:1c.0: MEM window: 0xe0300000-0xe06fffff
[ 0.387041] pci 0000:00:1c.0: PREFETCH window: 0x000000e0000000-0x000000e00fffff
[ 0.387053] pci 0000:00:1c.1: PCI bridge, secondary bus 0000:02
[ 0.387060] pci 0000:00:1c.1: IO window: 0x4000-0x4fff
[ 0.387069] pci 0000:00:1c.1: MEM window: 0xe0700000-0xe08fffff
[ 0.387078] pci 0000:00:1c.1: PREFETCH window: 0x000000e0900000-0x000000e0afffff
[ 0.387089] pci 0000:00:1c.2: PCI bridge, secondary bus 0000:03
[ 0.387096] pci 0000:00:1c.2: IO window: 0x5000-0x5fff
[ 0.387106] pci 0000:00:1c.2: MEM window: 0xe0b00000-0xe0cfffff
[ 0.387114] pci 0000:00:1c.2: PREFETCH window: 0x000000e0d00000-0x000000e0efffff
[ 0.387126] pci 0000:00:1c.3: PCI bridge, secondary bus 0000:04
[ 0.387133] pci 0000:00:1c.3: IO window: 0x6000-0x6fff
[ 0.387143] pci 0000:00:1c.3: MEM window: 0xe0f00000-0xe10fffff
[ 0.387151] pci 0000:00:1c.3: PREFETCH window: 0x000000e1100000-0x000000e12fffff
[ 0.387163] pci 0000:00:1e.0: PCI bridge, secondary bus 0000:05
[ 0.387170] pci 0000:00:1e.0: IO window: 0x1000-0x1fff
[ 0.387178] pci 0000:00:1e.0: MEM window: disabled
[ 0.387185] pci 0000:00:1e.0: PREFETCH window: disabled
[ 0.387214] alloc irq_desc for 17 on node -1
[ 0.387219] alloc kstat_irqs on node -1
[ 0.387232] pci 0000:00:1c.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 0.387242] pci 0000:00:1c.0: setting latency timer to 64
[ 0.387256] pci 0000:00:1c.1: enabling device (0000 -> 0003)
[ 0.387263] alloc irq_desc for 16 on node -1
[ 0.387267] alloc kstat_irqs on node -1
[ 0.387276] pci 0000:00:1c.1: PCI INT B -> GSI 16 (level, low) -> IRQ 16
[ 0.387286] pci 0000:00:1c.1: setting latency timer to 64
[ 0.387300] pci 0000:00:1c.2: enabling device (0000 -> 0003)
[ 0.387307] alloc irq_desc for 18 on node -1
[ 0.387311] alloc kstat_irqs on node -1
[ 0.387319] pci 0000:00:1c.2: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[ 0.387329] pci 0000:00:1c.2: setting latency timer to 64
[ 0.387343] pci 0000:00:1c.3: enabling device (0000 -> 0003)
[ 0.387350] alloc irq_desc for 19 on node -1
[ 0.387354] alloc kstat_irqs on node -1
[ 0.387362] pci 0000:00:1c.3: PCI INT D -> GSI 19 (level, low) -> IRQ 19
[ 0.387372] pci 0000:00:1c.3: setting latency timer to 64
[ 0.387385] pci 0000:00:1e.0: setting latency timer to 64
[ 0.387393] pci_bus 0000:00: resource 0 io: [0x00-0xffff]
[ 0.387399] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffff]
[ 0.387405] pci_bus 0000:01: resource 0 io: [0x2000-0x2fff]
[ 0.387411] pci_bus 0000:01: resource 1 mem: [0xe0300000-0xe06fffff]
[ 0.387417] pci_bus 0000:01: resource 2 pref mem [0xe0000000-0xe00fffff]
[ 0.387423] pci_bus 0000:02: resource 0 io: [0x4000-0x4fff]
[ 0.387429] pci_bus 0000:02: resource 1 mem: [0xe0700000-0xe08fffff]
[ 0.387435] pci_bus 0000:02: resource 2 pref mem [0xe0900000-0xe0afffff]
[ 0.387441] pci_bus 0000:03: resource 0 io: [0x5000-0x5fff]
[ 0.387447] pci_bus 0000:03: resource 1 mem: [0xe0b00000-0xe0cfffff]
[ 0.387452] pci_bus 0000:03: resource 2 pref mem [0xe0d00000-0xe0efffff]
[ 0.387458] pci_bus 0000:04: resource 0 io: [0x6000-0x6fff]
[ 0.387464] pci_bus 0000:04: resource 1 mem: [0xe0f00000-0xe10fffff]
[ 0.387470] pci_bus 0000:04: resource 2 pref mem [0xe1100000-0xe12fffff]
[ 0.387476] pci_bus 0000:05: resource 0 io: [0x1000-0x1fff]
[ 0.387482] pci_bus 0000:05: resource 3 io: [0x00-0xffff]
[ 0.387487] pci_bus 0000:05: resource 4 mem: [0x000000-0xffffffff]
[ 0.387553] NET: Registered protocol family 2
[ 0.387741] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.388329] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.389194] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.389595] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.389601] TCP reno registered
[ 0.389791] NET: Registered protocol family 1
[ 0.389830] pci 0000:00:02.0: Boot video device
[ 0.407266] Scanning for low memory corruption every 60 seconds
[ 0.407422] audit: initializing netlink socket (disabled)
[ 0.407443] type=2000 audit(1321680223.406:1): initialized
[ 0.435364] highmem bounce pool size: 64 pages
[ 0.435376] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.446816] VFS: Disk quotas dquot_6.5.2
[ 0.446964] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.448211] fuse init (API version 7.13)
[ 0.448404] msgmni has been set to 1648
[ 0.463139] alg: No test for stdrng (krng)
[ 0.463310] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.463319] io scheduler noop registered
[ 0.463323] io scheduler anticipatory registered
[ 0.463327] io scheduler deadline registered
[ 0.463419] io scheduler cfq registered (default)
[ 0.463666] alloc irq_desc for 24 on node -1
[ 0.463671] alloc kstat_irqs on node -1
[ 0.463690] pcieport 0000:00:1c.0: irq 24 for MSI/MSI-X
[ 0.463705] pcieport 0000:00:1c.0: setting latency timer to 64
[ 0.463915] alloc irq_desc for 25 on node -1
[ 0.463919] alloc kstat_irqs on node -1
[ 0.463934] pcieport 0000:00:1c.1: irq 25 for MSI/MSI-X
[ 0.463948] pcieport 0000:00:1c.1: setting latency timer to 64
[ 0.464146] alloc irq_desc for 26 on node -1
[ 0.464150] alloc kstat_irqs on node -1
[ 0.464164] pcieport 0000:00:1c.2: irq 26 for MSI/MSI-X
[ 0.464178] pcieport 0000:00:1c.2: setting latency timer to 64
[ 0.464377] alloc irq_desc for 27 on node -1
[ 0.464382] alloc kstat_irqs on node -1
[ 0.464396] pcieport 0000:00:1c.3: irq 27 for MSI/MSI-X
[ 0.464410] pcieport 0000:00:1c.3: setting latency timer to 64
[ 0.464569] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.464775] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.464911] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
[ 0.464925] ACPI: Sleep Button [SLPB]
[ 0.465036] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 0.465042] ACPI: Power Button [PWRF]
[ 0.468077] hpet_acpi_add: no address or irqs in _CRS
[ 0.468166] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.468309] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.468462] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 0.468964] 00:09: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.469177] 00:0a: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 0.470761] isapnp: Scanning for PnP cards...
[ 0.476948] brd: module loaded
[ 0.477975] loop: module loaded
[ 0.478160] input: Macintosh mouse button emulation as /devices/virtual/input/input2
[ 0.478341] ata_piix 0000:00:1f.2: version 2.13
[ 0.478370] ata_piix 0000:00:1f.2: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 0.478380] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[ 0.630743] ata_piix 0000:00:1f.2: setting latency timer to 64
[ 0.635049] scsi0 : ata_piix
[ 0.638828] scsi1 : ata_piix
[ 0.639219] ata1: SATA max UDMA/133 cmd 0x30b8 ctl 0x30cc bmdma 0x30a0 irq 18
[ 0.639226] ata2: SATA max UDMA/133 cmd 0x30b0 ctl 0x30c8 bmdma 0x30a8 irq 18
[ 0.639936] Fixed MDIO Bus: probed
[ 0.640012] PPP generic driver version 2.4.2
[ 0.640107] tun: Universal TUN/TAP device driver, 1.6
[ 0.640112] tun: (C) 1999-2004 Max Krasnyansky <This email address is being protected from spambots. You need JavaScript enabled to view it.>
[ 0.640295] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.640334] alloc irq_desc for 23 on node -1
[ 0.640339] alloc kstat_irqs on node -1
[ 0.640352] ehci_hcd 0000:00:1d.7: PCI INT A -> GSI 23 (level, low) -> IRQ 23
[ 0.640378] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 0.640385] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 0.640454] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 1
[ 0.640494] ehci_hcd 0000:00:1d.7: using broken periodic workaround
[ 0.640512] ehci_hcd 0000:00:1d.7: debug port 1
[ 0.644409] ehci_hcd 0000:00:1d.7: cache line size of 32 is not supported
[ 0.644496] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xe0284400
[ 0.658862] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 0.659067] usb usb1: configuration #1 chosen from 1 choice
[ 0.659129] hub 1-0:1.0: USB hub found
[ 0.659150] hub 1-0:1.0: 8 ports detected
[ 0.659276] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.659309] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.659372] uhci_hcd 0000:00:1d.0: PCI INT A -> GSI 23 (level, low) -> IRQ 23
[ 0.659386] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 0.659393] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 0.659471] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 0.659510] uhci_hcd 0000:00:1d.0: irq 23, io base 0x00003080
[ 0.659702] usb usb2: configuration #1 chosen from 1 choice
[ 0.659759] hub 2-0:1.0: USB hub found
[ 0.659775] hub 2-0:1.0: 2 ports detected
[ 0.659859] uhci_hcd 0000:00:1d.1: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[ 0.659872] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 0.659878] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 0.659945] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[ 0.659994] uhci_hcd 0000:00:1d.1: irq 19, io base 0x00003060
[ 0.660178] usb usb3: configuration #1 chosen from 1 choice
[ 0.660235] hub 3-0:1.0: USB hub found
[ 0.660249] hub 3-0:1.0: 2 ports detected
[ 0.660334] uhci_hcd 0000:00:1d.2: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[ 0.660345] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 0.660352] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 0.660419] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[ 0.660452] uhci_hcd 0000:00:1d.2: irq 18, io base 0x00003040
[ 0.660633] usb usb4: configuration #1 chosen from 1 choice
[ 0.660695] hub 4-0:1.0: USB hub found
[ 0.660709] hub 4-0:1.0: 2 ports detected
[ 0.660793] uhci_hcd 0000:00:1d.3: PCI INT D -> GSI 16 (level, low) -> IRQ 16
[ 0.660805] uhci_hcd 0000:00:1d.3: setting latency timer to 64
[ 0.660811] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[ 0.660896] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
[ 0.660942] uhci_hcd 0000:00:1d.3: irq 16, io base 0x00003020
[ 0.661126] usb usb5: configuration #1 chosen from 1 choice
[ 0.661184] hub 5-0:1.0: USB hub found
[ 0.661198] hub 5-0:1.0: 2 ports detected
[ 0.661393] PNP: No PS/2 controller found. Probing ports directly.
[ 0.668124] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.668143] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.668431] mice: PS/2 mouse device common for all mice
[ 0.668669] rtc_cmos 00:03: RTC can wake from S4
[ 0.668751] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
[ 0.668789] rtc0: alarms up to one month, y3k, 114 bytes nvram
[ 0.669025] device-mapper: uevent: version 1.0.3
[ 0.669245] device-mapper: ioctl: 4.15.0-ioctl (2009-04-01) initialised: This email address is being protected from spambots. You need JavaScript enabled to view it.
[ 0.718409] device-mapper: multipath: version 1.1.0 loaded
[ 0.718417] device-mapper: multipath round-robin: version 1.0.0 loaded
[ 0.723237] EISA: Probing bus 0 at eisa.0
[ 0.723248] Cannot allocate resource for EISA slot 1
[ 0.723254] Cannot allocate resource for EISA slot 2
[ 0.723258] Cannot allocate resource for EISA slot 3
[ 0.723263] Cannot allocate resource for EISA slot 4
[ 0.723268] Cannot allocate resource for EISA slot 5
[ 0.723273] Cannot allocate resource for EISA slot 6
[ 0.723285] EISA: Detected 0 cards.
[ 0.723290] cpuidle: using governor ladder
[ 0.723295] cpuidle: using governor menu
[ 0.724139] TCP cubic registered
[ 0.724473] NET: Registered protocol family 10
[ 0.725330] lo: Disabled Privacy Extensions
[ 0.725926] NET: Registered protocol family 17
[ 0.725986] Using IPI No-Shortcut mode
[ 0.726179] registered taskstats version 1
[ 0.726765] rtc_cmos 00:03: setting system clock to 2011-11-19 05:23:44 UTC (1321680224)
[ 0.726772] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 0.726776] EDD information not available.
[ 0.822747] ata1.00: ATA-7: INTEL SSDSA2M040G2GC, 2CV102M3, max UDMA/133
[ 0.822755] ata1.00: 78165360 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 0.831633] ata1.00: configured for UDMA/133
[ 1.170409] isapnp: No Plug & Play device found
[ 1.170655] scsi 0:0:0:0: Direct-Access ATA INTEL SSDSA2M040 2CV1 PQ: 0 ANSI: 5
[ 1.170977] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1.171170] sd 0:0:0:0: [sda] 78165360 512-byte logical blocks: (40.0 GB/37.2 GiB)
[ 1.171301] sd 0:0:0:0: [sda] Write Protect is off
[ 1.171308] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.171376] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.171715] sda: sda1 sda2 < sda5 >
[ 1.173799] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.240706] Freeing initrd memory: 12791k freed
[ 1.248968] Freeing unused kernel memory: 620k freed
[ 1.249476] Write protecting the kernel text: 4540k
[ 1.249523] Write protecting the kernel read-only data: 1668k
[ 1.288335] udev: starting version 151
[ 1.404114] usb 3-1: new full speed USB device using uhci_hcd and address 2
[ 1.599205] usb 3-1: configuration #1 chosen from 1 choice
[ 1.692170] Linux agpgart interface v0.103
[ 1.747104] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 1.747136] r8169 0000:01:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 1.747258] r8169 0000:01:00.0: setting latency timer to 64
[ 1.747268] r8169 0000:01:00.0: unknown MAC, using family default
[ 1.747327] alloc irq_desc for 28 on node -1
[ 1.747332] alloc kstat_irqs on node -1
[ 1.747354] r8169 0000:01:00.0: irq 28 for MSI/MSI-X
[ 1.748648] eth0: RTL8168b/8111b at 0xf80fa000, 38:60:77:0d:81:fc, XID 0c200000 IRQ 28
[ 1.786837] [drm] Initialized drm 1.1.0 20060810
[ 1.816314] agpgart-intel 0000:00:00.0: Intel IGD Chipset
[ 1.816672] agpgart-intel 0000:00:00.0: detected 8188K stolen memory
[ 1.827836] usbcore: registered new interface driver hiddev
[ 1.829463] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xd0000000
[ 1.831467] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:1d.1/usb3/3-1/3-1:1.0/input/input3
[ 1.831634] generic-usb 0003:046D:C52B.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:00:1d.1-1/input0
[ 1.834950] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:1d.1/usb3/3-1/3-1:1.1/input/input4
[ 1.835809] generic-usb 0003:046D:C52B.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:1d.1-1/input1
[ 1.842357] generic-usb 0003:046D:C52B.0003: hiddev97,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:1d.1-1/input2
[ 1.842410] usbcore: registered new interface driver usbhid
[ 1.842609] usbhid: v2.6:USB HID core driver
[ 1.860085] usb 5-2: new low speed USB device using uhci_hcd and address 2
[ 1.976359] i915 0000:00:02.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 1.976369] i915 0000:00:02.0: setting latency timer to 64
[ 1.990173] alloc irq_desc for 29 on node -1
[ 1.990180] alloc kstat_irqs on node -1
[ 1.990195] i915 0000:00:02.0: irq 29 for MSI/MSI-X
[ 1.990207] [drm] set up 7M of stolen space
[ 1.990966] [drm] initialized overlay support
[ 2.145342] usb 5-2: configuration #1 chosen from 1 choice
[ 2.162284] fb0: inteldrmfb frame buffer device
[ 2.162291] registered panic notifier
[ 2.162581] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[ 2.168419] vga16fb: initializing
[ 2.168428] vga16fb: mapped to 0xc00a0000
[ 2.168436] vga16fb: not registering due to another framebuffer present
[ 2.179626] input: Logitech USB Keyboard as /devices/pci0000:00/0000:00:1d.3/usb5/5-2/5-2:1.0/input/input5
[ 2.179787] generic-usb 0003:046D:C31C.0004: input,hidraw3: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-0000:00:1d.3-2/input0
[ 2.191378] [drm] Big FIFO is enabled
[ 2.227144] input: Logitech USB Keyboard as /devices/pci0000:00/0000:00:1d.3/usb5/5-2/5-2:1.1/input/input6
[ 2.227326] generic-usb 0003:046D:C31C.0005: input,hidraw4: USB HID v1.10 Device [Logitech USB Keyboard] on usb-0000:00:1d.3-2/input1
[ 2.260029] [drm] Big FIFO is enabled
[ 2.260043] [drm] Big FIFO is enabled
[ 2.260100] [drm] Big FIFO is enabled
[ 2.305557] Console: switching to colour frame buffer device 240x67
[ 2.617233] [drm] Big FIFO is enabled
[ 2.640219] [drm] Big FIFO is enabled
[ 2.992951] xor: automatically using best checksumming function: pIII_sse
[ 3.012012] pIII_sse : 5562.000 MB/sec
[ 3.012017] xor: using function: pIII_sse (5562.000 MB/sec)
[ 3.040183] device-mapper: dm-raid45: initialized v0.2594b
[ 3.107282] EXT4-fs (sda1): mounted filesystem with ordered data mode
[ 3.470738] Adding 1648632k swap on /dev/sda5. Priority:-1 extents:1 across:1648632k SS
[ 3.666152] udev: starting version 151
[ 3.895964] lp: driver loaded but no devices found
[ 4.777774] parport_pc 00:08: reported by Plug and Play ACPI
[ 4.777838] parport0: PC-style at 0x378, irq 7 [PCSPP]
[ 4.876372] lp0: using parport0 (interrupt-driven).
[ 4.876680] alloc irq_desc for 20 on node -1
[ 4.876686] alloc kstat_irqs on node -1
[ 4.876699] parport_pc 0000:05:00.0: PCI INT A -> GSI 20 (level, low) -> IRQ 20
[ 4.876707] PCI parallel port detected: 9710:9815, I/O at 0x1030(0x1028), IRQ 20
[ 4.876763] parport1: PC-style at 0x1030 (0x1028), irq 20, using FIFO [PCSPP,TRISTATE,COMPAT,ECP]
[ 4.949008] ppdev: user-space parallel port driver
[ 4.972434] lp1: using parport1 (interrupt-driven).
[ 4.972444] PCI parallel port detected: 9710:9815, I/O at 0x1020(0x1018), IRQ 20
[ 4.972502] parport2: PC-style at 0x1020 (0x1018), irq 20, using FIFO [PCSPP,TRISTATE,COMPAT,ECP]
[ 5.037679] type=1505 audit(1321680228.809:2): operation="profile_load" pid=588 name="/sbin/dhclient3"
[ 5.038155] type=1505 audit(1321680228.809:3): operation="profile_load" pid=588 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 5.038428] type=1505 audit(1321680228.809:4): operation="profile_load" pid=588 name="/usr/lib/connman/scripts/dhclient-script"
[ 5.068443] lp2: using parport2 (interrupt-driven).
[ 5.658810] r8169: eth0: link down
[ 5.659229] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 5.877274] alloc irq_desc for 22 on node -1
[ 5.877281] alloc kstat_irqs on node -1
[ 5.877295] HDA Intel 0000:00:1b.0: PCI INT A -> GSI 22 (level, low) -> IRQ 22
[ 5.877366] HDA Intel 0000:00:1b.0: setting latency timer to 64
[ 5.931152] type=1505 audit(1321680229.701:5): operation="profile_load" pid=792 name="/usr/share/gdm/guest-session/Xsession"
[ 5.935266] type=1505 audit(1321680229.705:6): operation="profile_replace" pid=793 name="/sbin/dhclient3"
[ 5.935754] type=1505 audit(1321680229.705:7): operation="profile_replace" pid=793 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 5.938910] type=1505 audit(1321680229.709:8): operation="profile_replace" pid=793 name="/usr/lib/connman/scripts/dhclient-script"
[ 5.953835] type=1505 audit(1321680229.725:9): operation="profile_load" pid=795 name="/usr/bin/evince"
[ 5.964088] type=1505 audit(1321680229.737:10): operation="profile_load" pid=795 name="/usr/bin/evince-previewer"
[ 5.977244] type=1505 audit(1321680229.749:11): operation="profile_load" pid=795 name="/usr/bin/evince-thumbnailer"
[ 6.014345] type=1505 audit(1321680229.785:12): operation="profile_load" pid=801 name="/usr/lib/cups/backend/cups-pdf"
[ 6.014974] type=1505 audit(1321680229.785:13): operation="profile_load" pid=801 name="/usr/sbin/cupsd"
[ 6.021851] hda_codec: ALC662 rev1: BIOS auto-probing.
[ 6.023538] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/input/input7
[ 6.036942] type=1505 audit(1321680229.809:14): operation="profile_load" pid=802 name="/usr/sbin/tcpdump"
[ 7.313516] CPU0 attaching NULL sched-domain.
[ 7.348197] CPU0 attaching sched-domain:
[ 7.348206] domain 0: span 0-1 level CPU
[ 7.348212] groups: 0 1
[ 7.348223] CPU1 attaching sched-domain:
[ 7.348228] domain 0: span 0-1 level CPU
[ 7.348233] groups: 1 0
[ 7.348606] CPU0 attaching NULL sched-domain.
[ 7.348614] CPU1 attaching NULL sched-domain.
[ 7.380184] CPU0 attaching sched-domain:
[ 7.380192] domain 0: span 0-1 level CPU
[ 7.380198] groups: 0 1
[ 7.380209] CPU1 attaching sched-domain:
[ 7.380214] domain 0: span 0-1 level CPU
[ 7.380219] groups: 1 0
[ 10.534599] CPU0 attaching NULL sched-domain.
[ 10.534610] CPU1 attaching NULL sched-domain.
[ 10.564140] CPU0 attaching sched-domain:
[ 10.564149] domain 0: span 0-1 level CPU
[ 10.564155] groups: 0 1
[ 10.564167] CPU1 attaching sched-domain:
[ 10.564171] domain 0: span 0-1 level CPU
[ 10.564177] groups: 1 0
[ 10.564529] CPU0 attaching NULL sched-domain.
[ 10.564536] CPU1 attaching NULL sched-domain.
[ 10.596144] CPU0 attaching sched-domain:
[ 10.596152] domain 0: span 0-1 level CPU
[ 10.596159] groups: 0 1
[ 10.596170] CPU1 attaching sched-domain:
[ 10.596175] domain 0: span 0-1 level CPU
[ 10.596180] groups: 1 0
[ 29.436356] I-pipe: Domain RTAI registered.
[ 29.436370] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 29.436376] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 29.436458] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 29.436463] PIPELINE layers:
[ 29.436468] f9c40e20 9ac15d93 RTAI 200
[ 29.436473] c085cb20 0 Linux 100
[ 29.485557] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 29.485847] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 29.485859] RTAI[sched]: hard timer type/freq = APIC/12500248(Hz); default timing: periodic; linear timed lists.
[ 29.485867] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1800137000 hz.
[ 29.485873] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 29.486008] RTAI[usi]: enabled.
[ 29.642963] RTAI[math]: loaded.
[ 29.773579] config string '0x378 out '
[ 40.632573] usb 1-5: new high speed USB device using ehci_hcd and address 4
[ 40.765577] usb 1-5: configuration #1 chosen from 1 choice
[ 40.814152] Initializing USB Mass Storage driver...
[ 40.814488] scsi2 : SCSI emulation for USB Mass Storage devices
[ 40.814924] usb-storage: device found at 4
[ 40.814948] usb-storage: waiting for device to settle before scanning
[ 40.814954] usbcore: registered new interface driver usb-storage
[ 40.817741] USB Mass Storage support registered.
[ 45.812375] usb-storage: device scan complete
[ 45.813243] scsi 2:0:0:0: Direct-Access LaCie itsaKey 0.00 PQ: 0 ANSI: 2
[ 45.816276] sd 2:0:0:0: Attached scsi generic sg1 type 0
[ 45.817023] RTAPI: ERROR: Unexpected realtime delay on task 1
[ 45.817035] This Message will only display once per session.
[ 45.817038] Run the Latency Test and resolve before continuing.
[ 45.817850] sd 2:0:0:0: [sdb] 7897088 512-byte logical blocks: (4.04 GB/3.76 GiB)
[ 45.818448] sd 2:0:0:0: [sdb] Write Protect is off
[ 45.818463] sd 2:0:0:0: [sdb] Mode Sense: 00 00 00 00
[ 45.818495] sd 2:0:0:0: [sdb] Assuming drive cache: write through
[ 45.821952] sd 2:0:0:0: [sdb] Assuming drive cache: write through
[ 45.821992] sdb: sdb1
[ 46.361819] sd 2:0:0:0: [sdb] Assuming drive cache: write through
[ 46.361846] sd 2:0:0:0: [sdb] Attached SCSI removable disk
[ 53.763662] RTAI[math]: unloaded.
[ 53.916106] SCHED releases registered named ALIEN RTGLBH
[ 53.948438] RTAI[malloc]: unloaded.
[ 54.048046] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 54.071340] I-pipe: Domain RTAI unregistered.
[ 54.071435] RTAI[hal]: unmounted.
[ 144.131465] I-pipe: Domain RTAI registered.
[ 144.131479] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 144.131485] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 144.131568] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 144.131573] PIPELINE layers:
[ 144.131578] fa10be20 9ac15d93 RTAI 200
[ 144.131583] c085cb20 0 Linux 100
[ 144.181621] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 144.181921] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 144.181933] RTAI[sched]: hard timer type/freq = APIC/12500248(Hz); default timing: periodic; linear timed lists.
[ 144.181941] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1800137000 hz.
[ 144.181946] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 144.182082] RTAI[usi]: enabled.
[ 144.338253] RTAI[math]: loaded.
[ 144.457072] config string '0x378 out '
[ 168.795879] RTAPI: ERROR: Unexpected realtime delay on task 1
[ 168.795893] This Message will only display once per session.
[ 168.795896] Run the Latency Test and resolve before continuing.
[ 190.566511] RTAI[math]: unloaded.
[ 190.680156] SCHED releases registered named ALIEN RTGLBH
[ 190.712417] RTAI[malloc]: unloaded.
[ 190.812045] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 190.818938] I-pipe: Domain RTAI unregistered.
[ 190.819030] RTAI[hal]: unmounted.
18 Nov 2011 18:37 #14931 by andypugh
I was expecting to see some numbers for the RTAI error in the dmesg something along the lines of 'the latest, 245050 was so anomalously large that…" but it isn't there.
What is your base thread period? (it should be somewhere in the HAL file)
19 Nov 2011 13:25 #14943 by BigJohnT
I did use the ram specified for the D525 and it seemed to be only one at New Egg.
