feedback in emc2
- fbd
25 Nov 2011 12:00 - 25 Nov 2011 14:16 #15089
by fbd
feedback in emc2 was created by fbd
I'm not sure that means feedback emc2.
Feedback is used for h-bridge or for motion control on the digital lineup.
Let us perform the following g-code G0 X0Y0, emc2 shows x = 0.00 y = 0.00, but the digital line shows the x = 0.06 y = 0.00; using feedback emc2 herself believes in the value of the line and finishing their need to position. I understand correctly?
Last edit: 25 Nov 2011 14:16 by fbd.
- Thank you received: 4992
25 Nov 2011 14:12 #15092
Replied by andypugh on topic Re:feedback in emc2
fbd wrote:
I am a little bit unsure if this is a new question, or a reply to another post which has been misplaced?
Probably.I understand you correctly?
- jmelson
- Thank you received: 159
27 Nov 2011 00:31 #15106
by jmelson
Replied by jmelson on topic Re:feedback in emc2
fbd wrote:
be sent to EMC in some manner. The scheme is that when the EMC interpreter
decodes the command for movement, the trajectory planner calculates a position
that is different from the current position. The PID routine computes the velocity
that is required, and sends a command for that to whatever interface commands
the servo amplifier to create movement. The PID routine monitors the movement
and adjusts the commanded velocity to minimize the difference between commanded
and actual position (the feedback).
Does this answer your question?
Jon
Any servo system where EMC is part of the servo loop needs position feedback toI'm not sure that means feedback emc2.
Jon
Time to create page: 0.065 seconds
