How to bind M62-M65 codes to parallel port?
- Thank you received: 5018
08 Dec 2011 15:27 #15483
Replied by andypugh on topic Re:How to bind M62-M65 codes to parallel port?
Eric_SJ wrote:
In HAL nomenclature "foo" is the signal, and motion.digital-in-00 and parport.0.pin-NN-in are pins.
parport.0.pin-NN-in is a HAL Output pin (it's an IN into the computer, but an OUT in HAL) and motion.digital-in-00 is an input pin.
A signal (like foo) can be connected on one or many lines to one output pin and as many input pins as you like. Where an output pin "writes" a value to the signal, and the input pins "read" the value from a signal into a component.
So
net foo input-pin
net foo output-pin
is exactly the same as
net foo input-pin output-pin
or
net foo output-pin input-pin.
You could also have
net foo input-pin
net foo input-pin-2 output-pin input-pin-3
net foo input-pin-4 input-pin5 input-pin-6
if you felt that way inclined. Or you could put them all on the same line.
That makes complete sense now, but I don't recall seeing anywhere in the documentation that a "wire" is needed to connect the signal to the pin.
So
net foo input-pin
net foo output-pin
or
You could also have
net foo input-pin
- Eric_SJ
08 Dec 2011 23:56 #15506
by Eric_SJ
Replied by Eric_SJ on topic Re:How to bind M62-M65 codes to parallel port?
AHA! Got it now. I was working with the assumption that motion.digital was a "signal" that I wanted to send to a pin...when in fact it was also a "pin" and I needed a foo "signal" to connect to my parallel output "pin".
Thanks for the clarification and help.
Time to create page: 0.073 seconds
