Heidenhain 11(micro)App sinusoidal linear encoders
  • jCandlish
  • jCandlish's Avatar Topic Author
  • Premium Member
  • Premium Member
09 Dec 2011 12:58 - 09 Dec 2011 12:58 #15511 by jCandlish
Specifically LS-303
Does the 7i49 support these scales directly or is a digitizing interpolator (like the EXE 600 series) necessary?
If an interpolator is necessary, other than Heidenhain, what is working?
_jC
Last edit: 09 Dec 2011 12:58 by jCandlish.
09 Dec 2011 15:55 #15516 by PCW
The 7I49 is really for resolvers, it might be possible to change the firmware to read the Heidenhain encoders but its not trivial. Also the 7I49 analog inputs are not right for the 11 uA Heidenhain signals
You really want a current/voltage (trransconductance amp) front end. This is possible but requires changing lots of 0603 SMD resistors on the card.
So if you have the interpolator, keep it...
We've kicked around the idea of using a DSPIC as a cheap Heidehain interpolator but have never developed sufficient ambition to actually lay one out, maybe next year...
Also Andy Pugh has a resolver interface in a Arduino, Its firmware could be modified to read the Heidenhain signals
A resolver interface and a interpolator do very similar things, the main difference is that the resolver
interface uses a carrier (AC excitation) so is a little more involved than an interpolator which effectively has DC excitation
  • jCandlish
  • Premium Member
  • Premium Member
09 Dec 2011 16:23 - 09 Dec 2011 17:04 #15518 by jCandlish
Great info PCW! Thanks so much.
Unfortunately I don't have an interpolator, execpt the one integrated into an old Elesta control.
I was thinking Arduino, checked their site and go-ogle, and came up empty.
Maybe Andy will chime in with his resolver solution, or is that documented somewhere on this site?
Are there any other non-Heidenhain (read less-expensive) off-the-shelf ways to interface Heidenhain linear encoders?
Thanks again
_jC
Last edit: 09 Dec 2011 17:04 by jCandlish. Reason: sspeling
10 Dec 2011 03:14 #15525 by cmorley
if you have time to search. Ebay often has heidenhain EXE interpolators for around $50.
www.ebay.com/itm/HEIDENHAIN-EXE-602-D-5-...&hash=item19cb5339d1
11 Dec 2011 01:32 #15541 by andypugh
<chime>
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?Res...oQuadratureConverter
I am not sure what the Heidenhains need, but some bits of that might help.
Time to create page: 0.150 seconds
