Encoder on Mill Spindle, What can I do besides RPM
- Harry_Y
09 Dec 2011 17:15 #15520
by Harry_Y
Encoder on Mill Spindle, What can I do besides RPM was created by Harry_Y
I am adding an encoder to my Lathe Spindle for threading (100 pules per rev + index)
(actually Quadrature, but only using what is needed)
If I add one to my Mill Spindle, What other capabilities
does it give me besides just reading RPM
Thank you
Thank you
- BigJohnT
- Thank you received: 1177
09 Dec 2011 18:50 #15521
by BigJohnT
Replied by BigJohnT on topic Re:Encoder on Mill Spindle, What can I do besides RPM
If you use both the A and B phase plus Z index you can rigid tap on both if EMC has control of the spindle and can reverse the spindle. Also with the encoder on the lathe you now can have CSS (Constant Surface Speed).
- Harry_Y
09 Dec 2011 19:13 #15522
by Harry_Y
Replied by Harry_Y on topic Re:Encoder on Mill Spindle, What can I do besides RPM
Thank you
I may need to look into adding speed and reversing control
Time to create page: 0.631 seconds
