Trying to set up 2nd machine for testing
12 Dec 2011 16:24 - 12 Dec 2011 16:50 #15591 by cwebs
I have emc running well with machine name "my_mill" want to set up another one for testing and learning. Used Stepconfig and made a second one named "Carls_cnc". Every thing seemed ok during the set up. Tested all three axis and joged machine. Set speed and acelaration ok. Go to dest top and click on the new Carls cnc icon and nothen. Emc will not start. My mill still works fine.
What can I do to get the second setup working. I want to setup a joypad and learn HAL but leave the working one alone. Thanks Carl
More info. Seems that the desktop icon is what is broken. Runs from the "Applications" Ok.
Last edit: 12 Dec 2011 16:50 by cwebs.
12 Dec 2011 17:14 #15596 by BigJohnT
Replied by BigJohnT on topic Re:Trying to set up 2nd machine for testing
Copy the command from your desktop shortcut and paste in a terminal window and see what error you get.
But I suspect the config name it the problem...
12 Dec 2011 19:43 #15602 by cwebs
No error codes. I had the same thing happen with the old computer. No problem, I can use it.
13 Dec 2011 10:00 #15625 by ArcEye
Replied by ArcEye on topic Re:Trying to set up 2nd machine for testing
Hi
Look in /home/yourfolder/Desktop
The NameofShortcut.desktop file should have a format like this
[Desktop Entry]
Name=EMC-HAL-SIM-LATHE
Exec=/usr/bin/emc '/home/yourname/emc2/configs/sim/lathe.ini'
Type=Application
Comment=
Icon=emc2icon
The single quotes around the file path and name is important, because it is launched through a shell and identifies it as a single arg.
If it looks OK rename the .ini to lowercase with no spacers and try that (rename both the actual file and the arg in the shortcut)
13 Dec 2011 16:48 #15636 by cwebs
ArcEye wrote:
Hi
[Desktop Entry]
Type=Application
Comment=
Icon=emc2icon
Does this info come from right click/properties ?
13 Dec 2011 18:06 #15640 by ArcEye
No it comes from opening a desktop shortcut and reading it.
Time to create page: 0.107 seconds
