USB
- SRT
12 Dec 2011 23:36 #15612
by SRT
USB was created by SRT
I was reading some posts from the users digest that said anything plugged into a USB will mess with the realtime? That means I need to find a new (old) mouse and keyboard? I arlso picked up a touch screen monitor that uses USB for the touch that I may not be able to use. I was wondering if this kind of info should be added to the getting started manual.
- BigJohnT
- Thank you received: 1176
12 Dec 2011 23:46 - 12 Dec 2011 23:46 #15613
by BigJohnT
Replied by BigJohnT on topic Re:USB
Userspace USB is fine like joypad, mouse, keyboard and touch screens. What is not possible is USB control of your stepper or servos.
Last edit: 12 Dec 2011 23:46 by BigJohnT.
- SRT
12 Dec 2011 23:47 #15614
by SRT
Replied by SRT on topic Re:USB
Ok thanks.
This is the post I read:
For the new bees here, stick a usb memory key into a port on the machine that runs emc, and watch emc stumble & upchuck all over itself. It is not pretty.
- BigJohnT
13 Dec 2011 00:00 #15615
by BigJohnT
That does sound like a hardware issue particular to that persons computer. I use USB sticks all the time with EMC and I never have to clean up puke from EMC.
- SRT
13 Dec 2011 00:06 #15616
by SRT
Maybe I need to quit reading so much..... I am really trying to wrap my head around this and do it as right as possible from the beginning.
Everybody here has been great so far. Thanks again for taking the time to help the less informed.
- Thank you received: 2161
13 Dec 2011 00:21 #15618
Replied by cmorley on topic Re:USB
I believe I remember reading another post a long time ago and that user had problems when they plug a USB device in or out while EMC was running.
Not everyone had this problem.
Do a latency test and plug a USB memory card in and out. You will get your answer.
- Harry_Y
13 Dec 2011 02:44 #15621
by Harry_Y
Replied by Harry_Y on topic Re:USB
cmorley wrote:
I did a bunch of a/b testing when I was setting up my computer
took notes, then wiped it clean and did a fresh install with the right settings
Time to create page: 0.066 seconds
